Hi there
Converted a file from DVD to H264 with Freemake Video Converter, which took only 50 minutes (using CUDA). Tried the same folder with VidCoder, & it took over 4 hours!!!
I haven't the time to waste on all my files if they are going to take that long, however Freemake didn't give me chapters or subtitles, yet Vidcoder does.
Which software can someone recommend that will give me the chapters etc, & at the same time use CUDA?
Did you compare the quality? See http://www.behardware.com/articles/828-27/h-264-encoding-cpu-vs-gpu-nvidia-cuda-amd-st...-and-x264.html
Maybe mediacoder can keep chapters and subs. -
My expeirence:
Lower the B-frames to 1 in mediacoder to keep quality
NVIDIA GeForce 8600 GT
Which Converter For MKV H264/ CQ/ CUDA Processing
By shagratt71 in forum Video ConversionReplies: 1Last Post: 8th Oct 2011, 13:41 -
Problems converting some xvid to h264 to append to another h264
By PlanetIndigo in forum Video ConversionReplies: 3Last Post: 6th Jun 2011, 14:13 -
cuda h264 very bad quality
By azor in forum Video ConversionReplies: 18Last Post: 26th Feb 2011, 08:13 -
Problem converting H264(mkv), keeps crashing while converting.
By weedelf in forum Video ConversionReplies: 4Last Post: 9th Apr 2009, 23:56 -
converting .h264 to DVD-5
By tj1182 in forum Authoring (DVD)Replies: 4Last Post: 28th Jan 2008, 11:05
