  1. Ok so i am a very big fan of using xenonmkv for all my file conversions and splitting in order for movies to work on my xbox when needed. However i recently ran into a little predicament....
    It seems that xenon only does 2 splits max. So for example, lets say i have a movie with a file size of 9gb. Zenonmkv would need to split this file 3 times in order for it to work on xbox (since xbox only reads files that are >4gb but unfortunately it still only splits it twice. So is there another program as good as xenonmkv that will do more than 2 splits of a movie (and convert them out of mkv) for use on the xbox?? Any help is appreciated
  2. Have you tried Gotsent?
  3. i will give it a try and thanks.
    Is gotsent pretty straight forward like xenonmkv is? in other words, can i simply click a few buttons and be good to go?
