hi all,
continuing my efforts to get virtualdub 1.9.11 going with x264vfw (x264vfw_37_2200bm_33968.exe)...
when i do a preview in virtualdub, i see MB in video data/projected file size, however, when the actual AVI file is saved it's only a few KB.
if i choose something other than x264vfw in compression, the file size is larger.
i've attached the x264vfw config in the attached.
what needs changing?
thanks,
dh.
If you are doing multipass/2-pass encoding you must "convert" twice, see https://forum.videohelp.com/threads/312870-Solved-How-to-do-2-pass-avi-encoding-with-VirtualDub-Mod (it should work similar for x264).
Or use one-pass or constant quantizer encoding mode instead. -
cool, thanks. i've set it to "Single pass - bitrate-based (ABR)" now, and success!
cheers,
dh. -
Need some help with VirtualDub and x264vfw
By Maukr in forum Newbie / General discussionsReplies: 1Last Post: 29th Jul 2012, 09:02 -
x264vfw, virtualdub and vegas?
By greatveemon in forum Newbie / General discussionsReplies: 5Last Post: 16th Jan 2011, 09:32 -
BD Rebuilder output files too small
By mpullar in forum Blu-ray RippingReplies: 9Last Post: 18th Mar 2010, 18:58 -
RipBot264 Output Too Small using CQ=22
By adammhaile in forum Blu-ray RippingReplies: 1Last Post: 5th Jan 2010, 12:49 -
Strange BD Rebuilder problem - Output files too small??
By YBS1 in forum Blu-ray RippingReplies: 1Last Post: 19th Sep 2009, 20:20
