Hello, I have a lot of tapes that I would like to convert and I'm looking for additional suggestions. Some background- I've tried 3 options so far and none have been quite satisfactory:
Sony DVD recorder- would be good except IRE Euro level, so it looks a bit washed out
Funai DVD recorder- too dark/blown out
Diamond VC500 USB - okay, but color a bit washed out and I've read hardware encoding produces better results
I posted over in the DVD Recorder section and people had some helpful info and suggestions for out-of-print models that sounded good, but I'm curious if there might be a PC option that would be easier than tracking down a discontinued unit. Basically, I want the capture quality to match the original tape. I'm not out to make some super impossible cleaned up copy or whatnot, but the colors, brightness and contrast must match the original.
I was recommended the Hauppauge HDPVR, but then I read a lot of reviews saying that it locks up with VHS tapes if you rewind/ff/stop/the tape switches material/etc. Is the HDPVR really that touchy with VHS sources? Aside from locking up, does it capture color/contrast properly? Finally, are there any similar devices that work well with VHS? Thanks much.
Question about capturing Doctor Who VHS tapes
By fatcharlie in forum Capturing and VCRReplies: 30Last Post: 3rd Apr 2011, 23:42 -
Question/Opinion: Capturing from VHS to digital, then to DVD
By SupaDupaMonkey in forum Capturing and VCRReplies: 12Last Post: 11th Jun 2009, 16:28 -
Capturing DV VHS deinterlace question
By bgmagic in forum Video ConversionReplies: 3Last Post: 13th Nov 2008, 08:57 -
Capturing from VHS to divX: Recommendations (Flicker & freezing proble
By roylayer in forum Capturing and VCRReplies: 2Last Post: 26th Sep 2008, 17:00 -
Qaulity Capture Card for VHS-DVD & Computer TV Viewing/Capturing
By RubicksCube13 in forum Capturing and VCRReplies: 1Last Post: 11th Nov 2007, 08:00
