Well I recived a new VCD recorder, and can record live broadcast, and from the DVD player, but a VCR Tape still locks up when recorded to the Terapin. any ideas why. please contact me if you have any seg. Thanks mwhecloc@yahoo.com
If it is an old tape this is a common problem with many video recording formats. A worn tape will likely produce corrupt sync pulses which means the Terrapin can't lock on properly to the incoming signal. If your VCR has a built in time base corrector try switching it on.
Macrovision works in this way to if your original tape is macrovision protected the vcr will output corrupt sync pulses meaning the signal is difficult to record. You can buy external devices designed to strip out the macrovision signal. -
This is a strange problem. The terapin will record the first 32 mins flawlessly, then, lockup, frozen picture, no sound. If the Video Sysnc is the problem, I'll switch VCRs. These tapes are not store baught, but recoreded off from cable. Thanks again.
I'm pretty sure this is a problem with the Terapin or the media. Why would all your tapes have video problems 32 minutes in? You could test this by recording live from your cable/sattelite. Just record more than 32 minutes of live broadcast and see if you experience that same problem. If you do, then you know it isn't your tapes or VCR.
Oh, and it can't be macrovision. The Terapin isn't affected by macrovision.
Have you tried several types and brands of media. I have tried Memorex audio grade CD-R's, Memorex Black CD-R's(just for kicks), TDK data grade CD-R's and Imation and TDK data grade CD-RW's. I've have uniformly good results with all of them.(Except for an audio sync problem on *some* DVD players, but the results are pretty much the same on all media I've tried.)
Good luck with it.
see ya,
Bullseye -
Sorry! I didn't notice that you'd already said you can record from live broadcast w/ no problems. I'd borrow someone else's VCR and see if that works properly. Or you could try recording live broadcast *through* your VCR into the Terapin.(VCR outs to Terapin ins) That'd be easier, but not as good a test.
Also, do other VCD/DVD players have trouble playing back the VCD's that freeze up after 32 min? Or does the Terapin quit recording after 32 min?
Good luck.
see ya,
Bullseye -
I made the mistake of buyin a Terapin VCD recorder last summer.
I had the same problems that you are describing-not to mention, the video quality was sub-vhs. I sent it back as defective.
I now have a Panasonic DMR-E20 DVD recorder and I love it. You can pick one up for around $700
Good luck
problems with dvd recorder
By john sheehan in forum DVD & Blu-ray RecordersReplies: 1Last Post: 26th Aug 2011, 13:43 -
Tevion TDR250HD DVD recorder problems
By aussiebloke in forum DVD & Blu-ray RecordersReplies: 3Last Post: 19th Feb 2010, 01:55 -
Total Recorder Professional Edition Problems
By Teac23 in forum AudioReplies: 0Last Post: 14th Jan 2009, 09:56 -
Problems with LG HDD/DVD Recorder 780
By cbgman in forum Newbie / General discussionsReplies: 1Last Post: 16th Oct 2008, 14:27 -
Audio problems with camcorder capture to dvd-r recorder
By illyad in forum CapturingReplies: 1Last Post: 9th Dec 2007, 07:53
