Hello everybody
I need to know the exact command line (with which parameters) Handbrake executes when it starts a conversion.
I had a look to Handbrake's log files, but the only options and parameters that I found are those of Handbrake itself. I need to know which are the corresponding ones used when FFmpeg actually makes the conversion (if I understood correctly that Handbrake is a GUI for FFmpeg...)
Thanks in advance!![]()
Falco2000, video newbie.
Let's everyone help each other. -
I guess that would be encoding MPEG2 then, not h264 through libx264 . I didn't even know handbreak could encode MPEG2, it must be a recent addition
I assumed you were talking about h264 from your other thread
https://forum.videohelp.com/threads/349703-Why-Handbrake-and-FFmpeg-MP4-x-264-conversio...e-so-different -
There is no reason to delete these threads - they aren't "stupid" questionsIs there a way to DELETE these stupid and unuseful threads of mine???
Maybe someone in the future will have the same questions as you looking for answers ? -
...yep. I've been an ffmpeg power user for years (http://www.deckerd26354.net/sites/shared/Scripts/ffmpeg/What_Are_Optimal_FFMPEG_Parame..._For_Video.htm), but I'm a newbie when it comes to using CFR instead of constant bitrate for HD and UHD titles. The only thing that handbrake doesn't do is allow users to set their own metadata, and I don't want to run handbrake then add metadata in a -C COPY command. It would be REALLY great if the next version of Handbrake would have the ability to either (or both) export handbrake's resulting parameters as an ffmpeg command, or add a feature to allow insertion of custom metadata items. 'Why would you want to do this?' - because one of these days I'll have all my movies stored in a data lake, with a streaming server such as plex or kodi on my edgenode, and it would be nice if the server could read the movie file custom metadata items. hmmm...I dunno, now that I think of it, if my suggestion doesn't happen maybe I could just use mysql to store the items anyway....comments?
Why Handbrake and FFmpeg MP4/x.264 conversion speeds are so different?
By falco2000 in forum Video ConversionReplies: 4Last Post: 30th Sep 2012, 10:10 -
How to convert MPG2 to lower bitrate with FFMPEG using Handbrake settings?
By falco2000 in forum Video ConversionReplies: 8Last Post: 25th Sep 2012, 10:37 -
ffmpeg command lines not working.
By PsyDonias in forum Video ConversionReplies: 23Last Post: 5th Dec 2011, 10:04 -
Help with FFMPEG command lines
By ricardouk in forum Video ConversionReplies: 11Last Post: 17th May 2008, 13:27 -
Get corresponding ffmpeg command after using ffmpegX
By npw in forum ffmpegX general discussionReplies: 2Last Post: 23rd Apr 2008, 02:29
