hi all,
i'm trying to get videodub 1.9.11 going with x264vfw (x264vfw_37_2200bm_33968.exe).
virtualdub has been configured as per:
timelapseblog.com/2009/08/04/using-virtualdub-for-time-lapse/
the config i've used for x264vfw is described in:
http://www.wcreplays.com/forums/showthread.php?t=113891
although i only have the Main tab (must be basic version?).
the warning message i get when trying to save as avi is:
x264vfw [warning]: frame MB size (324x216) > level limit (36864)
x264vfw [warning]: DPB size (3 frames, 80621568 bytes) > level limit (2 frames, 70778880 bytes)
i'm not sure what this means exactly... i've added 24 photos which are all 5184 x 3456 and all ~7.9 mb each.
any ideas?
thanks,
dh.
Because it exceeds the level you set
Most devices are limited to L4.1, the max resolution is 2048x1080 for that level
http://en.wikipedia.org/wiki/H.264/MPEG-4_AVC#Levels
You can use a higher level, but normally people would resize the photos to 1920x1080 if the intended target was a HDTV. Since your photo AR is 1.5, either pillarbox, or cropped view.
Unless you have a 4K projector or monitor, it's useless to view at your current resolution -
ok, the res was just off camera.
resized to 1920 x 1080 and the errors no longer occur.
dh.
Need some help with VirtualDub and x264vfw
By Maukr in forum Newbie / General discussionsReplies: 1Last Post: 29th Jul 2012, 09:02 -
Updating X264vfw
By hech54 in forum Video ConversionReplies: 1Last Post: 30th Jan 2011, 09:16 -
AE CS5 export x264vfw
By Impylse in forum EditingReplies: 3Last Post: 9th Oct 2010, 16:32 -
H.264 video is dim with overlay / x264vfw question
By serexl in forum Newbie / General discussionsReplies: 16Last Post: 9th Mar 2010, 21:07 -
Help with x264vfw
By ingeralhaosului in forum Video ConversionReplies: 1Last Post: 14th Jun 2008, 16:00
