Results 1 to 11 of 11
VLC
I want .m2ts because I frequently burn to blu ray and there is supposed to be no loss in quality.
I will try converting to mkv and see if that helps. I can't find a page on this site that tells how to convert from .mov to .mkv without loss of quality.Last edited by Onceler2; 29th Sep 2012 at 21:43.
Did you try another player? Certain versions of VLC are known to have playback problems
What does mediainfo (view=>text) say about the source mov ?
Many cameras that shoot h.264/mov shoot non compliant video for blu-ray (e.g. Canon DSLR's) . The bitrate is too high. They need to be re-encoded anyways -
Media info says that the video is 33.4Mbps and the audio is 1536 Kbps
mkvtoolnix , but this won't help you for blu-ray unless your blu-ray player is a model that supports mkv
Can you use view=>text, copy & paste the text view back hereMedia info says that the video is 33.4Mbps and the audio is 1536 Kbps
What model is the camera ?
Did you try another software player? (just for testing purposes, it might be that VLC is giving you incorrect preview)
Does playing the original MOV have any issues ?Last edited by poisondeathray; 30th Sep 2012 at 10:21.
General
Complete name : F:\HiDef\Canon new\Newer\103___06\MVI_0099.MOV
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt
File size : 187 MiB
Duration : 44s 878ms
Overall bit rate : 35.0 Mbps
Encoded date : UTC 2012-06-05 18:37:43
Tagged date : UTC 2012-06-05 18:37:43
CNTH : ð¦•?JõýÃ
com.apple.quicktime.make : Canon
com.apple.quicktime.model : Canon PowerShot SX260 HS
Video
Format : AVC
Format profile : Baseline@L5.0
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=12
Codec ID : avc1
Bit rate : 33.4 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.672
Stream size : 179 MiB (96%)
Language : English
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : sowt
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 8.22 MiB (4%)
Language : English
canonpc1742
Once the audio was converted to AC3 I never had a problem playing it back on my PS3 -
Encode .mov to mkv/m2ts?
By Wischmop in forum Video ConversionReplies: 1Last Post: 1st Jan 2012, 05:49 -
Error While Playing x264/m2ts Files On KMPlayer Using DXVA
By Stonecaper in forum Software PlayingReplies: 0Last Post: 20th Jan 2011, 13:39 -
M2TS to MOV/MP4
By thunderclap82 in forum Video ConversionReplies: 2Last Post: 25th Mar 2010, 10:02 -
M2TS (x264) to avi or something else
By vassock in forum Video ConversionReplies: 3Last Post: 12th Nov 2009, 03:58 -
M2TS to Mov?
By Benhermies in forum Newbie / General discussionsReplies: 0Last Post: 13th Sep 2009, 23:17
