I was recently looking at a collection of Digital Camcorders and noticed some had the MiniDv logo on them and others Digital 8, I was wondering whats the main difference between them if any ?
Regards: Patsym1
I believe it's the size of the tape.
I know that MiniDV uses a small cassete will Digital 8 uses a tape like the standard 8 and High 8 tapes.
I have not used Mini-DV personality, I have a D8 camera.
I like it because it's backwards compatible with my 8 and High 8 tapes. -
Same here. The main reason (apart from passthrough feature) I bought Sony D8 camcorder is because I have a huge collection of old 8mm tapes.
Thanks for the quick reply guys, but basically I was wondering if there was a differance in quality or are the both the same?.
Regards: Patsym1 -
If you havn't already done so, you should check out DV.com.
http://www.dv.com/community/forums.jhtml?sid=1
There's a section there about cameras. I just checked it out and they're offline till Monday.
Seven -
I'm not sure, but I think MiniDV(using firewire) is 500 lines of resolution. and High 8(using SVideo) is 400 lines of resolution. If it is an Firewire output, resolution is 500 LOR. If it is an SVideo output, resolution is 400 LOR. If it is an Analog A/V output, resolution is 240 LOR. Hope this helps.
I bought digital camcoder recently and before that I did some research about digital8 and miniDV formats.
Digital8 - Sony invented and supported this format - they use standard 8mm tapes and record video in digital format instead of analog.
All digital8 camcoders could play both 8mm tapes recorded in digital format and old analog.
MiniDV tapes are ~1.5 times smaller and also use digital format.
The quality of digital8 and miniDV is the same.
The only advantage miniDV camcoders are more compact comparing to digital8.
Finaly I bought miniDV Sony PC9 camcoder for it's small size.
But before that I bought Sony IP5 microMV camcoder - it's the smallest camcoder available with tapes which are 70% size of miniDV tapes.
I returned it next day after test drive. The zoom is so small - you hardly can use it - but it's nothing comparing to the bug Sony made:
At the end of each clip there is a freeze frame for a fraction of a second.
Looks terrible.
So if you want smaller size - go with miniDV. If size doesn't matter you could save money buying digital8. -
alot of D8 cameras have firewire
OHHHHHHHHHHHHHHHHHH
Get a camera with A/V input n u will have the best capture device in the world.
Analogue to Digital Capabilities on Sony DCR-PC MiniDV Series ???
By darito in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 22Last Post: 20th Apr 2012, 23:30 -
Which miniDV or Digital 8 cam has the best TBC for transfering videos?
By theaveng in forum Capturing and VCRReplies: 12Last Post: 16th May 2009, 02:03 -
8mm to Digital - Record to MiniDV vs Pass-through
By tripecac in forum Capturing and VCRReplies: 10Last Post: 1st Jul 2008, 17:46 -
What is the Best MiniDV Camcorder with analog/digital pass-through
By DigitalGuard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 20th Jun 2007, 15:18 -
Need help choosing a good miniDV digital camcorder with still capability
By newmom in forum Newbie / General discussionsReplies: 1Last Post: 10th Jun 2007, 19:07
