Results 1 to 15 of 15
  1. Anonymous
    Guest
    ok, i have a windows desktop and i just downloaded this one show thats in an MKV format
    i tried converting it to an MP4 with AVS Video Converter and it successfully converted it but it didnt have the subtitles
    so is there a way i can convert an MKV to an MP4 and still have subs
    Nov 2003
    West Texas
    Does the original mkv file have H264 video in it? If so, look at this: https://www.videohelp.com/tools/MkvToMp4
  3. Anonymous
    Guest
    is there a way i can find out if it is h264
    Nov 2003
    West Texas
    Install MediaInfo and examine the file with it. Do a custom install of MediaInfo so you don't get any toolbars installed.
    I find the Tree view within MediaInfo to be the most informative.
    If it does have H264, it will probably show up as Format: AVC.
    (Advanced Video Codec)
  5. Anonymous
    Guest
    its avc
    what should i do now?
    Nov 2003
    West Texas
    Try MKVtoMp4 on the file.
  7. Anonymous
    Guest
    are there any specific instructions on how to do it cuz ive tried it twice and both times didnt work
    all i did was, add the file and clicked start
    everytime it was done, there was a huge x next to the subtitle
  8. What kind of subtitles? e.g SRT? SSA? ASS ?
    MP4 container has limited subtitle support . It can hold SRT and TTXT subs . You could use yamb for example
    If it's another format, then you might have to hardsub it (re-encode and burn in the subs instead of soft subs, where you can toggle them on/off)
  9. Anonymous
    Guest
    its ssa
  10. Anonymous
    Guest
    ok, i found out a way to extract the subtitles from the mkv with mkvtoolnix and mkvextractgui
    is there any way i can work things out from there
  11. Either convert to srt (you will lose any fancy formatting and fonts) , or hardsub it
  12. Anonymous
    Guest
    i was able to convert to srt using vobsub.
    what do i do after, use yamb?
  13. push create mp4 option, add the streams (video, audio, subs), push next until it' s done
  14. Anonymous
    Guest
    on yamb, after i add the streams, it says cannot find mkvextract please provide a correct path in the settings
  15. put it (mkvextract.exe) in the mkvtoolnix directory
    or go to the settings => advanced settings => extractors => specify directory for mkvextract
    make sure you're using yamb 2.1.0.0 beta 2 , not the earlier version
