Hi all,
I have some MTS files that I would like to split/cut at certain minutes.
And upload to youtube.
What is the free software that I can do this? I want to keep original video quality the same as possible.
Maybe add a title to the video.
Thanks all.![]()
tsMuxeR:
1. start tsMuxer GUI
2. use "Input->add" to add your file
3. activate and set "Split & cut->Splitting->Split by duration every X sec" to 60*Y, where Y is the number of minutes
4. set "Input->Output" to "M2ts" (you can later rename the m2ts extension to mts if you want)
5. hit "Input->Start muxing"
afaik Transportstreams to not have any flags to set a title or other metadata,...Maybe add a title to the video.
(you could load your source, set titles and split the output similar to the way tsMuxeR does it using mkvmerge if you are fine with .mkv as output) -
Thanks Selur for the info.
I followed your step but use cut instead, no splitting.
When I tried to cut 0.34s to 0.54s, I am not getting that file. I still have the same video as the original video. Any idea why?
MUXOPT --no-pcr-on-video-pid --new-audio-pes --vbr --cut-start=0.34s --cut-end=0.54s --vbv-len=500
V_MPEG4/ISO/AVC, "C:\00009.MTS", fps=29.970, insertSEI, contSPS, track=4113
A_AC3, "C:\00009.MTS", track=4352
S_HDMV/PGS, "C:\00009.MTS",bottom-offset=24,font-border=2,text-align=center,video-width=1920,video-height=1080,fps=29.97, track=4608
How to merge multiple .mts files (canon HF) into one single .mts file
By frmsuv2van in forum Video ConversionReplies: 15Last Post: 5th Sep 2014, 22:21 -
How can split a mts movie file without loose the quality
By siopilos in forum EditingReplies: 5Last Post: 15th Feb 2012, 15:57 -
Use .MTS files in Final Cut Pro while keeping original dates in the files
By Winterburn in forum MacReplies: 3Last Post: 18th Aug 2011, 17:21 -
HD Cam wrote .mts files to my flash card but put in another cam still mts
By Onceler2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 15th Dec 2009, 07:15 -
MTS Files
By krysia1974 in forum Newbie / General discussionsReplies: 1Last Post: 16th May 2008, 11:25
