My Canon Gl2 camcorder was dropped on the ground when the LCD screen was open. There was no visible damage done, however the LCD screen did seem slighty more flimsy at the hinge when playing around with it.
Is there any way to fix this? There are some screws at the hinge, and I wonder if I open them I may be able to view the problem?
Results 1 to 16 of 16
The screws are so small i can't seem to get enough torque to turn them.... anyone else had this problem
You probably need smaller (and better-made) screwdrivers.
Some of the electronics from Japan can be hard to work with.
Been there, done that. Hated it.Want my help? Ask here! (not via PM!)
Best Buy had a screwdriver kit awhile back. I bought one to get the small philips head screwdriver to remove a hard drive from a laptop. Even then it was a bear to get the screws out. The drive screws had some kind of goop on them to keep them tight and not loosen.
Probably locktite on the screws. You can always try gripping the shaft of the screwdriver with pliers.
Best Buy usually doesn't have the right precision quality, nor the correct Japanese sizes.
Those "close enough" sizes are what bore holes into the screw head.
The pliers advice = spot on. I've had to do that myself.
Good input, loster.Want my help? Ask here! (not via PM!)
I still haven't found a small enough philips screwdriver to fit in the screws... looks like i will have to buy one. anyone have any recommendations as to where i can find one?
Look for a 0 philips screwdriver in your local hardware store.
Are you sure the screws are philips heads?Some are 3 pointed.
It is the smallest sized slot screwdriver I could find at the store. I was quite certain it said size 0. I thought it would work in a phillips screw (4-pointed screw) but apparently it doesn't... will do some more searching tomorrow
You can buy 00 and 000 online.
If you're in a huge city (Chicago, Dallas, LA, Miami, etc), then some hobby shops may have what's needed.
There are also non-USA sizes used in Japan. You'll have a hell of a time finding a kit.
I got mine thanks to a friend in Japan sending one overseas.
I've had to use it to dismantle oddball gear from Sony and Nikon.Want my help? Ask here! (not via PM!)
I hate to argue with you but JIS and Phillips are separate specifications not separate sizes.
http://www.rjrcooltools.com/jis.cfm
There is supposed to be a indication if the drive is JIS but I have only seen it on large sizes.
Also Philips size 0 is way too large for electronics.
You could try this set it has worked well for me.
http://www.homedepot.com/buy/6-piece-precision-screwdriver-set-008-060-hky.html -
That Homedepot screwdriver set looks exactly like the one I bought at Best Buy. Only different name on mine, (Skil brand).
The smallest slot size shows 2.0mm and smallest Phillips also 2.0mm. No numberd sizes like size 0. I don't know what the equivalent 2.0mm numbered size is.
Edit: I found it: 2.0mm equals 00 size.Last edited by TreeTops; 5th Oct 2012 at 12:22.
Video capturing with a Canon GL2
By dfisher052 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 30th Aug 2009, 15:24 -
GL2 LCD Monitor Display
By HarveyCee in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 27th May 2009, 17:32 -
Getting a film look with a Canon GL2
By pbear23 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 2nd Oct 2008, 19:17 -
Canon GL2, XL1, XL1S, or...?
By nopEda in forum Newbie / General discussionsReplies: 7Last Post: 27th Aug 2008, 16:38 -
Canon GL2 16:9
By kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 6th Oct 2007, 00:13
