I have a number of m2v files that I want to trim. I also have ac3 files that go with the m2v files. I got these by using Isobuster and vobedit. I am trying MPEG Video Wizard with the m2v files. Is it possible to just edit the ac3 file and save it with no video. Thanks. The reason the video was out of sync was it was including a clip at the beginning that I did not know was there.
anything you trim the m2v with will cause the audio to go out of sync because you are cutting just the video and not the audio. you should be able to re-sync them and trim the audio with studio. mpg2cut2 is another m2v tool.
I found how to save just the audio. Is there a good easy to use freeware program to trim ac3 files. Thanks.
Help with m2v files
By Mikhel in forum Video ConversionReplies: 0Last Post: 19th Feb 2012, 07:22 -
Trimming DVB *.ts files?
By W_Eagle in forum DVB / IPTVReplies: 4Last Post: 14th May 2009, 17:12 -
join .m2v files?
By just in forum Newbie / General discussionsReplies: 5Last Post: 24th Nov 2008, 21:11 -
edit m2v files?
By SUPERIOR in forum EditingReplies: 2Last Post: 16th May 2008, 03:42 -
Convert m2v files to avi?
By drgregur in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 29th Mar 2008, 18:54
