    Jul 2012
    Germany
    Hello!
    I recently upgraded to version 3.1.2.5. Now crashes do not appear as often as usualy , and I can now create mkvs from BR-folders with subs!
    BUT: For some reason the mkvs are not cueable (no fast forward/backward). Not with vlc, nor with my Fantech Mediaplayer connected to my TV! This was no problem at all with former versions! Perhaps a broken timecode? Someone here had the same problem and found a setting to avoid this problem?
    thanks,
    dag0
    You could try remux with mkvtoolnix, add the mkv and make new one. Be sure to disable header compression(file->options->disable header compression by default or something in mkvtoolnix)
    Or try something else to convert your blu-rays to mkv like ripbot264.
    Jul 2012
    Germany
    Thanks, but I tried Ripbot, it supported only one language stream and and i didn't like its batch-conversion. Remuxing could be a workaround but is not really a solution!
    EDIT: I realize just now, that Ripbot has a new Batch-Mode. But BR is not supported? And I can choose only one language and all subs, none or just one? What if I want to have german and english subs?
    Jul 2012
    Germany
    I tried to demux 2 of those files generated by xmediarecode with MeGui. In both cases I got "invalid EBML data". What does that mean?
    MKV, 1 video track, 1 audio track, 2:27:33, 24p /1.001
    1: h264/AVC, 1080p24 /1.001 (16:9)
    2: DTS Hi-Res, 5.1 channels, 16 bits, 2046kbps, 48kHz, dialnorm: -4dB
       (core: DTS, 5.1 channels, 16 bits, 1509kbps, 48kHz, dialnorm: -4dB)
    [v01] Extracting video track number 1...
    [a02] Extracting audio track number 2...
    [a02] Extracting DTS core...
    [a02] Removing DTS dialog normalization...
    [a02] Patching bitdepth to 24 bits...
    [v01] Muxing video to Matroska...
    [a02] Creating file "Z:\movie\1\PARFUM\T2_Audio - English.dts"...
    [a02] Invalid EBML data (1).  <ERROR>
    [v01] Invalid EBML data (1).  <ERROR>
    Aborted at file position 2146172928.  <ERR
    OR>
    EDIT:
    Following this tip I get several error-messges obviously according to broken header data and an abort.
