  1. tomsta79 tomsta79's Avatar
    Sep 2012
    england
    hi every one i am looking for the answer to the following.. i have a sub box which is called blade 7000 hd. and i want to know if any one knows if it is PROTECTED BY HDCP?..because i want to buy a good hd capture card so i can record from my hd box. thanks
  2. Check the manual. Call the manufacturer. Or hook up a display that doesn't support HDCP. But almost every cable and satellite box is protected by HDCP. The odds are very much against you.
  3. Banned
    Freedonia
    I cannot take you seriously when you write "no" and "no.s" instead of "know" and "knows".
  4. Good one jman... I have noticed that the grammar and spelling is getting worse on this forum. Mostly newbies.
  5. Banned
    New York, US
    The influence of texting.
  6. tomsta79 tomsta79's Avatar
    Sep 2012
    england
    having a clue pal. what do you mean?
