I'm encoding xvid avi (because that's what my crappy iview2600 supports in my living room) the tv shows I recorded on my main, catch is it only uses 100% of 400 % maybe 100.9 at the most there anyway to compile fmpegx and ffmpeg to use mulicre I looked for a commandline window in the encoding options but I can find such animal help
terramir
added videocard had to downclock my proc got 10 C hotter in my case time to ducts that sucker ;@ had to down my overclock was 2200mhz now 2100 mhz :'(
If you want to encode with ffmpeg from the command line on Mac OS X, then I suggest gettting a newer binary from http://go.to/osxffmpegcompiling, or compile your own. I haven't tested the CPU percentages, though.
FFMPGX not reading source file information
By neurofungus in forum ffmpegX general discussionReplies: 4Last Post: 2nd Dec 2010, 16:24 -
Multicore suggestion?
By pardu in forum LinuxReplies: 18Last Post: 27th Jun 2010, 20:18 -
DVD to X264 multicore?
By bagmand22 in forum DVD RippingReplies: 1Last Post: 25th Jun 2010, 02:50 -
Multicore Conversion Programs
By Merkaba188 in forum Newbie / General discussionsReplies: 9Last Post: 2nd Aug 2009, 18:33 -
Error downloading ffmpgX. Help?
By tuftedpuffin in forum ffmpegX general discussionReplies: 3Last Post: 9th Oct 2007, 23:27
