    Apr 2012
    Hungary
    I am looking for a converter software that can convert my mp4 files to wmv. I would like it to do the conversion with no, or minimal loss in quality. I need the same fps, bitrate, resolution, etc. in the output, everything should remain the same, only the encoding should change. I want to stabilize the videos with Mercalli V2, but it only works with WMV input correctly.
    What would be the suitable software for me?
    Here is a sample from those that should be converted:
  2. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Easy mate. Try Windows Movie Maker, part from Windows Live Essentials 2012.
    Its make a very close quality file.
    Look here (1080p@59,94 at 15Mb bitrate):
    http://www.mediafire.com/?v8qa8zk8nnvc93h
    Claudio
    Apr 2012
    Hungary
    Some simplier solution would be better. Windows Movie maker struggles a lot until it finishes preparing the mp4 video. It is too much time to wait until I can start converting. It would be better to add everything at the beginning, and leave the program work.
  4. Member bat999's Avatar
    Feb 2008
    Hi
    (It's not really possible/practical to make a 'lossless' conversion from MP4 to WMV.)
    To do the job with FFmpeg the command is like this:-
    ffmpeg -i SANY0016.MP4 -c:v wmv2 -b:v 20M -c:a wmav2 -b:a 192k output.wmv
    (Change the bitrates, if you like.)
    Then you can make a preset for WinFF.
    From here ---> http://winff.org/html_new/
    Information here ---> http://code.google.com/p/winff/wiki/HowToMakePresets
    Preset Name:-
    mp42wmv
    Preset Label:-
    MP4 to WMV
    Preset Command Line Parameters:-
    Output File Extension:-
    wmv
    Category:-
    WMV
