    Sep 2012
    Bracknell
    I have MTS files and want to burn them onto a DVD a normal player will read. What do I need to do? Can anyone please help?
  2. Banned
    New York, US
    Popular suggestions for MTS to DVD are TMPGenc Authoring Works or MultiAVCHD. Depends on whether you want DVD or BluRay.
    Sep 2012
    Bracknell
    Just normal DVD.
  4. Member wulf109's Avatar
    Jul 2002
    ConcertXDVD will convert most file formats to DVD playable on any standalone.
    Sep 2012
    Bracknell
    Although I used a TDK DVD-RW disc the writer doesn't recognise it? Is this common? I have a Sony Vaio so should I buy Sony DVDs?
  6. Banned
    New York, US
    TDK, SONY, and others like Maxell and other (formerly) famous disc brands, have dropped in quality to the point where they are now considered junk -- no better than generic store brands. The widely available discs most members would recommend is Verbatim "AZO" discs (the word "AZO" will appear somewhere on the label). Verbatim does make an economy line -- aka lower quality line -- that most shops now carry. Avoid them. If necessary, get AZO on the internet.
    While many players can read DVD-RW (and they're handy for testing), some can't. the DVD standard is DVD-R. For dual-layer DVD's, use DVD+R dual layer.
