Hello all...
I have been trying to rip and burn my blu-ray movies as backups...and am having quite a time of it.
I have burned approx. 10 disc (25gig ea) with no success.
I foune MilOtis's.pdf and followed it to a tee. I get stuck a little more than mid way with "Failed video encode, aborted"
It seems to me that my ffdshow is incorrect, however I have the latest offered.
Here is my log file...if anyone can help me out with this, I would be appreciated.
Thanks for looking...Mods...if this is in the wrong place, please move it.
Thanks a bunch
Paul
LOG:
[09/21/12] BD Rebuilder v0.42.03 (beta)
[12:13:25] Source: THE_DARK_KNIGHT_PLAYLIST_00100
- Input BD size: 32.66 GB
- Approximate total content: [02:32:13.332]
- Target BD size: 22.95 GB
- Windows Version: 6.1 [7601]
- MOVIE-ONLY mode enabled
- Auto Quality: Good (Very Fast), ABR
- Decoding/Frame serving: DirectShow
- Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640
[12:13:25] PHASE ONE, Encoding
- [12:13:25] Processing: VID_00007 (1 of 1)
- [12:13:25] Extracting A/V streams [VID_00007]
- [12:25:43] Reencoding video [VID_00007]
- Source Video: VC-1, 1920x1080
- Rate/Length: 23.976fps, 218,981 frames
- Bitrate: 19,070 Kbs
- [12:25:43] Reencoding: VID_00007, Pass 1 of 1
- Encode failed. Aborting.
- BD-Rebuilder v0.42.03 (beta)
- AVISYNTH Version: 2.5.8.0, Ok
- HAALI Splitter: 1.11.96.14, Ok
- FFDSHOW: 4486, not recommended version
- WIN7 preferred AVC CODEC: Ok
- WIN7 preferred VC-1 CODEC: Ok
- WIN7 preferred MPEG2 CODEC: Ok
- FFDSHOW VC-1 set incorrectly: [0]
- FFDSHOW MPEG2 set incorrectly: [0]
- FFDSHOW AVC set to "libavcodec": Ok
- AnyDVD settings check: Ok.
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
[12:26:45] - Failed video encode, aborted
DVDFab to rip.
BD-Rebuilder to shrink.
ImgBurn to burn.
Other guides/methods not necessary.Want my help? Ask here! (not via PM!)
Thanks for replying...this is the BD-Rebuilder logs....and as you can see it failed the encode
Well, I forget what exactly is in that guide, but no matter. You're configured wrongly.
1) Use *ONLY* the versions of ffdshow, Haali, and Avisynth listed on the first page of the BDRB bug report thread. Here:
http://forum.doom9.org/showthread.php?t=143716
2) You're on Windows 6.1 (7601), that's Windows 7, right? (Fill in your details). Delete your BDRB folder. Uninstall ffdshow, Haali, and Avisynth. For good measure, you could use CCleaner to clean up any registry items associated with them, but you probably won't need to do that. Create a new folder for BDRB, unzip the latest version of BDRB in it.
Here's the important part:
Right-click the executable and select "Run as Administrator". BDRB will offer to configure everything correctly for you. Let it.
3) Make sure you specify a working files location.
That's it. Good luck.Pull! Bang! Darn!
PDF secured
By Jomapil in forum ComputerReplies: 6Last Post: 1st Sep 2012, 11:18 -
Problem backing up Blu-Ray using BD Rebuilder with milOtis method
By TJMac44 in forum Blu-ray RippingReplies: 15Last Post: 7th Mar 2011, 14:43 -
Is there a PDF for ffmepgX ?
By midiw in forum ffmpegX general discussionReplies: 3Last Post: 20th Jan 2011, 09:23 -
Best PDF Editor..
By Soccerman77 in forum ComputerReplies: 1Last Post: 4th Nov 2010, 19:50 -
eBooks to .pdf?
By rotuts in forum MacReplies: 8Last Post: 23rd Oct 2010, 02:59
