Hello I've capture a movie with cam + audio.
video in h264 audio in MP3.
unfortunatly, the audio speed is varying during the play, I mean that the voice of the speaker (the one i've recorded) become very low and then go to the duck voice. This going randomly.
is there a way to correct that?
I've tried to extract the audio to wave with VirtualDub, same thing
rencode it, same thing
Thank you for any help.
If there were some steady state narrowband noise (like motor hum), you could lock onto the frequency of the hum and every place where it changes pitch, you could use a autotune (pitch-changer) to correct it and keep it at the same freq. Thus any other sounds would also be corrected the same amount.
Other that that lucky break, you will probably have to do this manually and in segments. What audio tools do you have available?
Something like this usually only happens when your camcorder's timebase is $H!t. It probably also messes with video framerate...
In the future, consider going "double system" (where you separately record the V+A with a camcorder and the A with a portable audio recorder, then sync back up later on in post).
Have you tried playing the original clip on any other device? (Just a guessSometimes playback on the PC can compromise the audio to the supposed improvement of the video using "Reclock".
Scott -
nice soft audacity
, well I've tried lot's of effects but nothing was magic.
I've done it manually, changing the speed of the sequences
@ Cornucopia well no background noise unfortunatly.
You're right next time we wil separate sound and un compress to mix that once all recorded.
Thanks for all
A linux tool for detecting glitches in video files (of varying formats)?
By jemenake in forum LinuxReplies: 1Last Post: 16th Feb 2012, 18:42 -
Combining clips of varying bitrates, but maintaining quality?
By Grunberg in forum EditingReplies: 7Last Post: 22nd Jun 2011, 20:38 -
Adding varying colours to subtitles?
By scifisam in forum SubtitleReplies: 4Last Post: 5th Nov 2010, 10:03 -
Audio is half the speed to video
By pixaren in forum Capturing and VCRReplies: 1Last Post: 2nd Nov 2010, 06:40 -
Audio file speed too fast
By Marco6 in forum ffmpegX general discussionReplies: 1Last Post: 4th Apr 2008, 12:49
