When I mux, using ImagoMPEG-Muxer, a .m2v I made from an .avi using FitCD and HC_gui and an .ac3 I demuxed using VirtualDub and then downmixed multichannel to Dolby Digital Pro Logic II in MeGUI I get bad audio. It sounds like a beeping noise or something in the background. This has never happened to me before with .mkvs. The audio sounds fine before I mux it but after it sounds horrible. How do I fix this?
Actually this is what I'm trying to do, AVI to MPEG-2 with AC3 audio...Crap I forgot to save it as .m2v instead of .mpg because it set it to .mpg by default. Aww man all that time gone. Only bad thing is it's the paid version. :/ I guess I'll have to get it for future conversions. Great guide though. If anyone knows freeware that can do this let me know.
http://members.dodo.net.au/~jimmalenko/AVI2DVD.htm -
You're not making any sense. Not to me anyway. You want an MPEG with AC3 audio? That's what ImagoMPEG-Muxer does.
You made an MPG but want the M2V back out of it? Demux it then. One way is to open the MPG in DGIndex and then go File->Save Project and Demux Video. You'll get the M2V, the audio, and a D2V project file which you don't need.
You want to make a DVD using freeware? There are dozens of free programs that do that. Try Avs2DVD. It can use the free HCEnc. Which you already know about so, again, none of this makes any sense to me. -
Ahhh noooo!! Lol.
1. Got avisynth script from FitCD for my avi source.
2. Used it in HC_gui. Got a .m2v.
3. Opened VirtualDub and demuxed the audio from the avi.
4. Downmixed it to Dolby Digital Pro Logic II in MeGUI because it had to many channels.
5. Muxed it in ImagoMPEG-Muxer. Got bad beeping audio in the background.
6.Why not just use the AC3 audio?
Original:
Audio
Format : AC-3
Format/Info : Audio Coding 3
Duration : 1h 46mn
Bit rate mode : Constant
Bit rate : 640 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 490 MiB (100%)
7.Have you tried any other muxer? Like the old tmpgenc (under file->tools->multiplexer)
8. Followed this guide but this involves using the paid version and for now I only have the trial.
This is great but it gave me an mpg. The problem with that is is that I want to change the audio bitrate to 448 instead of 384 I think it is...
9.
Sorry for the confusion...If that doesn't work out I think I'll leave the audio as is...Actually that's probably the best thing to do since I guess the DVD's you buy in the store use 384 too...Or so I assume. I don't really have any clue.
Muxing .m2v & .ac3 to .TS file
By randronoth in forum Video ConversionReplies: 3Last Post: 21st Jun 2011, 02:21 -
.m2v outputs from ffmpegX won't compile in DVD-SP 4 (internal muxer error)
By bbartley9 in forum ffmpegX general discussionReplies: 4Last Post: 21st Aug 2010, 03:57 -
free m2v+mp2 multiplex (other than ImagoMPEG)?
By tff in forum Video ConversionReplies: 3Last Post: 4th Jun 2009, 09:31 -
m2v + ac3 problem?
By just in forum Newbie / General discussionsReplies: 2Last Post: 21st Oct 2008, 17:24 -
Noob Troubles: DVD w/ Multi-Angles & Commentary + m2v & ac3 joining
By ssfblue in forum Newbie / General discussionsReplies: 5Last Post: 28th Nov 2007, 11:54
