    Sep 2012
    lancaster PA USA
    Hello all, I am a new AVStoDVD user. I like the program and used it yesterday for the first time, worked perfect. However today i was converting YouTube concert video MP4 files to Mpeg2 to make a DVD, like i did yesterday, and this time the resultant output files no longer had the original name. They all say DVD_0, DVD_1 etc. Yesterday they had the name. If i had not caught this early i would have no idea which track is which, so i can load my tracks in the proper order for burning. I can rename them, but why did the names go away? How can i fix this? Thanks!!
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Are these names in the program.....or are you talking about the final product DVD?
    https://www.videohelp.com/dvd#struct
    Sep 2012
    lancaster PA USA
    I am talking about the files AVStoDVD converted and deposited in the output folder. They would still have the same name, but the .MP4 was now .mpg. These files i would load into my burning program to burn to disk. Now the files only say DVD_0, DVD_1 and i dont know why.
    Sep 2012
    lancaster PA USA
    I was wrong, i just converted TWO separate Videos, and the outputed into ONE file, DVD_0. Something is wrong here. I MUST have the files outputed as individual files, with the .mpg code on the end how can i fix this? This program worked perfect yesterday. Why is this happening?? see attached pic I removed the whole proggram, and reinstalled it, in case i may have screwed something up. The only thing i did upon reinstall is set it to NSTC and the audio bitrate to 448. Nothing else. So why the problem today? please advise fix. i cannot believe this process of downloading, processing and burning YouTube videos to as a DVD that you can actually play would be so hard. this his now on day 8, at 5:30 am!!
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    In avstodvd click on the arrow right to Output and select Muxed mpeg2 file.
    Sep 2012
    lancaster PA USA
    pics of opened DVD_0 folder
    Sep 2012
    lancaster PA USA
    ok, trying that now
    Sep 2012
    lancaster PA USA
    Hey, that worked perfect!!! Thanks Super-Duper-Moderator!!! First for the very fast response so early in the morning, and with the correct answer to boot! I do NOT remember that muxing box yesterday when i first ran the program, nor did i adjust that setting. but oh well, i am converting like mad now, thanks again!!
