    Sep 2012
    wellington
    Hi,
    I would like to convert rmvb files to AVI files with TENcoder video converter.
    Can someone explain to me?
    Thanks in advance
    If you have no idea how to use it maybe you should try something easier where you just load the rmvb and choose to avi. Like freemake video converter (adware!!!)....
    Or else you load the rmvb, under codec choose xvid, under audio choose mp3 and convert. You probably want to adjust more settings like video size, bitrate, etc.
  3. Member ozok's Avatar
    Oct 2011
    Turkey
    Hello I am TEncoder's author.
    @rimutaka TEncoder does not support rmvb extension as input for now. But you can open rmvb files by clicking to Add button then Add Files. when add file dialog comes up select "All Files" for file type.
    I added two ss showing the procedure. Note that these are from next release.
    Also for further questions see TEncoder thread.
    Image Attached Images
    Sep 2012
    wellington
    Hi Baldrick,
    My Tencoder version is 2.4.2745
    I will give a try.
    Sep 2012
    wellington
    Thanks Ozok
  6. Member ozok's Avatar
    Oct 2011
    Turkey
    Rmvb support is added to TEncoder with version 2.6.
