I am doing the usual conversion from MKV to MP4 for PS3 playback. Having some trouble where the source files have DTS audio. Xmedia Recode is producing unreadable files. I am unable to playback on VLC or MPC.
for Video, I select Video Copy
for Audio, I select Convert, AC3, 48000, 5.1, Constant bitrate, 640
I am however able to use PS3Muxer to produce a usable m2ts with the same source file. But I would prefer to use Xmedia to produce MP4s
Any advice?
Details of sourcefile:
Format : Matroska
Format version : Version 2
File size : 3.28 GiB
Duration : 43mn 43s
Overall bit rate : 10.7 Mbps
Writing application : mkvmerge v4.8.0 ('I Got The...') built on May 24 2011 03:12:58
Writing library : libebml v1.2.0 + libmatroska v1.1.0
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 43mn 43s
Bit rate : 9 228 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.186
Stream size : 2.75 GiB (84%)
Writing library : x264 core 116 r2019 9cc407d
Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=18 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=9228 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Audio
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 43mn 43s
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 472 MiB (14%)
Default : Yes
Forced : No
XMedia Recode problem: No audio !
By penang in forum Newbie / General discussionsReplies: 12Last Post: 17th Mar 2012, 00:29 -
Convert DTS-MA to DTS with XMedia Recode?
By smackyourfupa in forum Blu-ray RippingReplies: 3Last Post: 14th Apr 2011, 08:23 -
XMedia Recode
By thezanny in forum Video ConversionReplies: 2Last Post: 10th Apr 2011, 06:24 -
Xmedia Recode Crashing when converting to MKV
By Des in forum DVD RippingReplies: 4Last Post: 30th Dec 2010, 09:37 -
XMedia Recode v2.2.2.0 DVD->MKV (H264AVC+AC3) Ms Visual C++ Runtime Error
By Bonie81 in forum DVD RippingReplies: 2Last Post: 13th May 2010, 11:32
