tsmuxer gives me an error with unsupported format being the header of the error and a description of some tracks not recognized and have been ignored...
I'm trying to process an mkv container to bd-r format and I just cant get tsmuxer to work or any other program that is dependant on it. I also have a slow pc so I dont want to re-encode it...
Here is the mkv info:
General
Complete name : C:\Users\Michael\Desktop\Men in Black 3\Men in Black 3.mkv
Format : Matroska
File size : 13.5 GiB
Duration : 1h 45mn
Overall bit rate : 18.3 Mbps
Encoded date : UTC 2012-09-06 23:37:24
Writing application : mkvmerge v5.3.0 ('I could have danced') built on Feb 9 2012 10:38:07
Writing library : libebml v1.2.3 + libmatroska v1.3.0
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 45mn
Bit rate : 16.1 Mbps
Nominal bit rate : 16.8 Mbps
Width : 1920 pixels
Height : 1040 pixels
Display aspect ratio : 16/9
Frame rate : 23.976 fps
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.351
Writing library : x264 core 125 r2208 d9d2288
Encoding settings : cabac=1 / ref=4 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=11 / psy=1 / psy_rd=1.10:0.05 / mixed_ref=1 / me_range=48 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=18 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=240 / rc=2pass / mbtree=1 / bitrate=16800 / ratetol=1.0 / qcomp=0.70 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.20 / aq=2:1.10
Audio
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 1h 45mn
Bit rate mode : Constant
Bit rate : 1536 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
Resolution : 16 bits
Text
Format : S_HDMV/PGS
Codec ID : S_HDMV/PGS
Chapters
Language : English
1 : 00:00:00.000 00:00:00.000
2 : 00:06:09.578 00:06:09.578
3 : 00:11:27.478 00:11:27.478
4 : 00:16:58.809 00:16:58.809
5 : 00:22:36.230 00:22:36.230
6 : 00:31:24.633 00:31:24.633
7 : 00:37:36.421 00:37:36.421
8 : 00:42:43.019 00:42:43.019
9 : 00:48:55.850 00:48:55.850
10 : 00:53:58.235 00:53:58.235
11 : 00:59:27.773 00:59:27.773
12 : 01:05:52.782 01:05:52.782
13 : 01:11:56.312 01:11:56.312
14 : 01:19:50.619 01:19:50.619
15 : 01:27:57.063 01:27:57.063
16 : 01:35:30.683 01:35:30.683
Closed Thread
Like tsmuxer...
By fits79 in forum Video ConversionReplies: 12Last Post: 31st Dec 2012, 09:04 -
Unsupported audio format in MKV file on LG 47LW5600 TV.
By kmplsv in forum Video ConversionReplies: 5Last Post: 23rd Feb 2012, 09:03 -
Unsupported format or damaged file -> ?
By ermetekos in forum EditingReplies: 1Last Post: 31st Mar 2010, 11:56 -
Unsupported FLV codec or format
By lovyagin in forum EditingReplies: 25Last Post: 11th Dec 2008, 23:13 -
Premiere 6.5 - unsupported compression format.
By vodmare in forum EditingReplies: 3Last Post: 28th Jan 2008, 16:51
