Hello,
Im trying to add subtitles to a movie, but subtitles workshop doesnt show any picture when I put any video.
Im trying .mov and .avi files.
What codecs I need ?
Maybe I have to change some properties ?
If you have a totally fresh system install and don't have any of the "usual" codecs installed you will need to get them obviously.
Stay away from codec packs! Just get what you need.
Use mediainfo and open the files you are working on. It will tell you what codecs were used. Then go and download the latest versions of those codecs and only those codecs, just get what you need nothing more.
Just make sure you get the 32bit codecs if you are running a 32bit OS and 64bit for 64bit os.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
If its mov its probably h264 or quicktime. Do you have quicktime installed? It should work with that. If not download h264 (I thinks its actually x264).
Codec packs are not looked upon favorably here. They can have unforseen complications. Just get the codec you need individually.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
All I can suggest, if you haven't already tried it, is to use another subtitle program. That or reencode your video to another format and try that. But of course keep your original as your source file.
MOV files won't play audio - RAM problem?
By MJW01 in forum AudioReplies: 1Last Post: 18th Nov 2011, 06:26 -
How do i play these mov files?
By perfection in forum Software PlayingReplies: 3Last Post: 11th Sep 2010, 16:42 -
FCP MOV to x264 produces separate Audio and Video MP4 output files?
By skywriter in forum ffmpegX general discussionReplies: 3Last Post: 10th Feb 2010, 16:49 -
Play .mov files with FFDShow
By loekverhees in forum Newbie / General discussionsReplies: 13Last Post: 11th Sep 2009, 11:45 -
New Video Card Can't Play AVI files
By DrFaroohk in forum ComputerReplies: 3Last Post: 16th Mar 2009, 16:10
