If I capture, in Virtualdub, an AVI with audio, I can frameserve to cce 2.50: VirtualDub->cce. If I turn off the Audio capture, then capture an AVI file with VirtualDub, then I can no longer frameserve to cce 2.50. I get this error message as soon as I try to open the .vdr file in cce:
The instruction at "0x004029c7" referenced memory at "0x00000008". The memory could not be "read".
Does anyone know how I can solve this?
Not sure why you're capturing without an audio source, but I digress...
CCE needs audio input or else it produces an error or just crashes in my case. In VDub, under Audio, select WAV source and choose any old wav you have handy, doesn't matter what size. Then when you frameserve, CCE should have no problems - then uncheck the Audio file in the CCE project settings. -
I don't need the audio of the original scene; I'm gonna mux in some music later. So there's no point in losing all the frames that VirtualDub is gonna drop to keep the audio in sync when I don't need that audio.Not sure why you're capturing without an audio source, but I digress...
Thanks for your suggestion. I'll try it.
Frameserve from VirtualDub64 to CCE
By pchan in forum Video ConversionReplies: 5Last Post: 11th Feb 2012, 07:23 -
CCE Encoding timecode error and pulldown
By dannybz in forum Authoring (DVD)Replies: 22Last Post: 16th Aug 2009, 11:45 -
CCE, MP4 and AviSynth Error
By Maikeru-sama in forum Video ConversionReplies: 28Last Post: 11th Jun 2008, 05:24 -
Vdub frame serving to CCE ?, UPDATE ..Fixed the Error
By theewizard in forum Video ConversionReplies: 15Last Post: 1st Feb 2008, 00:24 -
Error while encoding with CCE SP2
By 1gnition in forum Capturing and VCRReplies: 11Last Post: 4th Jul 2007, 05:46
