The link here doesn't work. Help please.
Matthew
heck54 is quite right. In addition I would add that some hacks only work on models sold in specific parts of the world, such as Australia, and they don't work on the same model sold elsewhere due to hardware differences. You can also look into seeing if you can find previous versions of firmware and downgrade as sometimes hacks only work on older firmwares. However, there's no guarantee that you will be able to find older firmware or that the device will let you install it. Some players cannot have their firmware downgraded. Sometimes with the hacks you're just out of luck.
Did the Region Code Management screen come up after you inserted the CD?
Euroline DVD100 DVD Player Region all region code/hack?
By mjgjhb in forum Newbie / General discussionsReplies: 0Last Post: 21st Jul 2011, 10:26 -
NON-region DVD player hack...
By cwb in forum DVD & Blu-ray PlayersReplies: 10Last Post: 24th Sep 2009, 17:53 -
Dvd player locked due to bad region hack :-S
By A$$hole in forum Newbie / General discussionsReplies: 6Last Post: 12th Jan 2009, 10:17 -
Need Help: Region Hack for DVD Player Toshiba SD-6100KU Thanks
By Panchogun in forum DVD & Blu-ray PlayersReplies: 0Last Post: 15th Nov 2008, 12:40 -
Microvision In Car Dvd Player - need region hack please!
By vanishingbluepoint in forum Newbie / General discussionsReplies: 0Last Post: 27th Sep 2008, 19:38
