Results 1 to 20 of 20
    Nov 2009
    Mexico
    I'm in a bit of a predicament, hopefully someone here can help me.
    I have a bunch of WAV files. I extracted them from an Xbox game, and they use a codec that no player supports natively, as far as I can tell. Someone reverse engineered the codec and made it available via the internet; I installed it, and I can play the files with MPC-Home Cinema and Windows Media Player.
    The problem is converting these WAV files to a more... compatible format. I don't know if there are any free converters that can use the codecs I have installed on my system. The ones I use (Audacity and fre.ac) keep trying to use their own built-in codecs, so they stop because they can't handle this particular codec.
    So, my question is, is there an audio conversion program that won't use its own built-in codecs, and that will let me use the one I installed?
    Thanks.
  2. DECEASED
    Jun 2009
    Heaven
    If it's a DirectShow/ACM codec, then you can use Graphstudio to do that job.
    Assuming the audio doesn't have more than 2 channels, just choose the appropriate output filters, namely WavDest and File Writer.
    EDIT: oops, Goldwave should be able to do the job as well.
    EDIT 2: if it's an ACM codec, I think Winamp can handle it too.
    Nov 2009
    Mexico
    I tried Winamp, it couldn't handle it. Maybe earlier versions used ACM codecs but the latest version doesn't seem to anymore.
    I'll give the other two tools a shot. Thanks.
    Nov 2009
    Mexico
    Well, neither of them worked. Graphstudio and Goldwave can't open the files. I tried Wavosaur, nope. ACM Converter, nada.
    What the hell is up with these files...?
  5. Member bat999's Avatar
    Feb 2008
    You need to provide a sample file.
    Otherwise it's guesswork.
    Nov 2009
    Mexico
    ... you know what, never mind. I just found out that FFMPEG supports this format. I'm such an idiot...
    If you still want the sample files so you can do your own tests, lemme know. I've sorted out my issues, at least...
  7. DECEASED
    Jun 2009
    Heaven
    Please say which one:
    [C:\]
    =>ffmpeg -codecs
    ffmpeg version N-43921-ga366bea Copyright (c) 2000-2012 the FFmpeg developers
      built on Aug 26 2012 20:57:47 with gcc 4.7.1 (GCC)
      configuration: --enable-gpl --enable-version3 --disable-pthreads --enable-runtime-cpudetect --
    enable-avisynth --enable-bzlib --enable-frei0r --enable-libass --enable-libcelt --enable-libopen
    core-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --enable-libmp3lame -
    -enable-libnut --enable-libopenjpeg --enable-librtmp --enable-libschroedinger --enable-libspeex
    --enable-libtheora --enable-libutvideo --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-li
    bvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
      libavutil      51. 70.100 / 51. 70.100
      libavcodec     54. 54.100 / 54. 54.100
      libavformat    54. 25.104 / 54. 25.104
      libavdevice    54.  2.100 / 54.  2.100
      libavfilter     3. 13.101 /  3. 13.101
      libswscale      2.  1.101 /  2.  1.101
      libswresample   0. 15.100 /  0. 15.100
      libpostproc    52.  0.100 / 52.  0.100
    Codecs:
     D... = Decoding supported
     .E.. = Encoding supported
     ..V. = Video codec
     ..A. = Audio codec
     ..S. = Subtitle codec
     ...I = Intra frame-only codec
     DEV. mpeg1video           MPEG-1 video
     DEV. mpeg2video           MPEG-1 video (decoders: mpeg2video mpegvideo )
     ..V. mpegvideo_xvmc       MPEG-1/2 video XvMC (X-Video Motion Compensation)
     DEV. h261                 H.261
     DEV. h263                 H.263 / H.263-1996, H.263+ / H.263-1998 / H.263 version 2
     DEV. rv10                 RealVideo 1.0
     DEV. rv20                 RealVideo 1.0
     DEVI mjpeg                Motion JPEG
     D.VI mjpegb               Apple MJPEG-B
     .EVI ljpeg                Lossless JPEG
     D.VI sp5x                 Sunplus JPEG (SP5X)
     DEVI jpegls               JPEG-LS
     DEV. mpeg4                MPEG-4 part 2 (encoders: mpeg4 libxvid )
     DEVI rawvideo             raw video
     D.V. msmpeg4v1            MPEG-4 part 2 Microsoft variant version 1
     DEV. msmpeg4v2            MPEG-4 part 2 Microsoft variant version 2
     DEV. msmpeg4v3            MPEG-4 part 2 Microsoft variant version 3 (decoders: msmpeg4 ) (encod
    ers: msmpeg4 )
     DEV. wmv1                 Windows Media Video 7
     DEV. wmv2                 Windows Media Video 8
     DEV. h263p                H.263+ / H.263-1998 / H.263 version 2
     D.V. h263i                Intel H.263
     DEV. flv1                 FLV / Sorenson Spark / Sorenson H.263 (Flash Video) (decoders: flv )
    (encoders: flv )
     DEV. svq1                 Sorenson Vector Quantizer 1 / Sorenson Video 1 / SVQ1
     D.V. svq3                 Sorenson Vector Quantizer 3 / Sorenson Video 3 / SVQ3
     DEVI dvvideo              DV (Digital Video)
     DEVI huffyuv              HuffYUV
     D.VI cyuv                 Creative YUV (CYUV)
     DEV. h264                 H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 (encoders: libx264 libx264r
    gb )
     D.V. indeo3               Intel Indeo 3
     D.V. vp3                  On2 VP3
     DEV. theora               Theora (encoders: libtheora )
     DEVI asv1                 ASUS V1
     DEVI asv2                 ASUS V2
     DEV. ffv1                 FFmpeg video codec #1
     D.V. 4xm                  4X Movie
     D.VI vcr1                 ATI VCR1
     DEVI cljr                 Cirrus Logic AccuPak
     D.VI mdec                 Sony PlayStation MDEC (Motion DECoder)
     DEV. roq                  id RoQ video (decoders: roqvideo ) (encoders: roqvideo )
     D.V. interplayvideo       Interplay MVE video
     D.V. xan_wc3              Wing Commander III / Xan
     D.V. xan_wc4              Wing Commander IV / Xxan
     D.V. rpza                 QuickTime video (RPZA)
     D.V. cinepak              Cinepak
     D.V. ws_vqa               Westwood Studios VQA (Vector Quantized Animation) video (decoders: vq
    avideo )
     D.V. msrle                Microsoft RLE
     DEV. msvideo1             Microsoft Video 1
     D.V. idcin                id Quake II CIN video (decoders: idcinvideo )
     D.VI 8bps                 QuickTime 8BPS video
     D.V. smc                  QuickTime Graphics (SMC)
     D.V. flic                 Autodesk Animator Flic video
     D.V. truemotion1          Duck TrueMotion 1.0
     D.V. vmdvideo             Sierra VMD video
     D.VI mszh                 LCL (LossLess Codec Library) MSZH
     DEVI zlib                 LCL (LossLess Codec Library) ZLIB
     DEV. qtrle                QuickTime Animation (RLE) video
     DEV. snow                 Snow
     D.V. tscc                 TechSmith Screen Capture Codec (decoders: camtasia )
     D.V. ulti                 IBM UltiMotion (decoders: ultimotion )
     D.VI qdraw                Apple QuickDraw
     D.VI vixl                 Miro VideoXL (decoders: xl )
     D.V. qpeg                 Q-team QPEG
     DEV. png                  PNG (Portable Network Graphics) image
     DEVI ppm                  PPM (Portable PixelMap) image
     DEVI pbm                  PBM (Portable BitMap) image
     DEVI pgm                  PGM (Portable GrayMap) image
     DEVI pgmyuv               PGMYUV (Portable GrayMap YUV) image
     DEVI pam                  PAM (Portable AnyMap) image
     DEVI ffvhuff              Huffyuv FFmpeg variant
     D.V. rv30                 RealVideo 3.0
     D.V. rv40                 RealVideo 4.0
     D.V. vc1                  SMPTE VC-1
     D.V. wmv3                 Windows Media Video 9
     D.VI loco                 LOCO
     D.VI wnv1                 Winnov WNV1
     D.V. aasc                 Autodesk RLE
     D.V. indeo2               Intel Indeo 2
     D.V. fraps                Fraps
     D.V. truemotion2          Duck TrueMotion 2.0
     DEVI bmp                  BMP (Windows and OS/2 bitmap)
     D.V. cscd                 CamStudio (decoders: camstudio )
     D.V. mmvideo              American Laser Games MM Video
     DEV. zmbv                 Zip Motion Blocks Video
     D.V. avs                  AVS (Audio Video Standard) video
     D.V. smackvideo           Smacker video (decoders: smackvid )
     D.V. nuv                  NuppelVideo/RTJPEG
     D.V. kmvc                 Karl Morton's video codec
     DEV. flashsv              Flash Screen Video v1
     DEV. cavs                 Chinese AVS (Audio Video Standard) (AVS1-P2, JiZhun profile) (encoder
    s: libxavs )
     DEVI jpeg2000             JPEG 2000 (decoders: j2k libopenjpeg ) (encoders: j2k libopenjpeg )
     D.V. vmnc                 VMware Screen Codec / VMware Video
     D.V. vp5                  On2 VP5
     D.V. vp6                  On2 VP6
     D.V. vp6f                 On2 VP6 (Flash version)
     DEVI targa                Truevision Targa image
     D.V. dsicinvideo          Delphine Software International CIN video
     D.V. tiertexseqvideo      Tiertex Limited SEQ video
     DEVI tiff                 TIFF image
     DEV. gif                  GIF (Graphics Interchange Format)
     D.V. dxa                  Feeble Files/ScummVM DXA
     DEVI dnxhd                VC3/DNxHD
     D.VI thp                  Nintendo Gamecube THP video
     DEVI sgi                  SGI image
     D.V. c93                  Interplay C93
     D.V. bethsoftvid          Bethesda VID video
     D.VI ptx                  V.Flash PTX image
     D.VI txd                  Renderware TXD (TeXture Dictionary) image
     D.V. vp6a                 On2 VP6 (Flash version, with alpha channel)
     DEVI amv                  AMV Video
     D.V. vb                   Beam Software VB
     DEVI pcx                  PC Paintbrush PCX image
     DEVI sunrast              Sun Rasterfile image
     D.V. indeo4               Intel Indeo Video Interactive 4
     D.V. indeo5               Intel Indeo Video Interactive 5
     D.V. mimic                Mimic
     D.VI rl2                  RL2 video
     D.V. escape124            Escape 124
     DEV. dirac                Dirac (decoders: dirac libschroedinger ) (encoders: libschroedinger )
     D.V. bfi                  Brute Force & Ignorance
     D.V. cmv                  Electronic Arts CMV video (decoders: eacmv )
     D.V. motionpixels         Motion Pixels video
     D.V. tgv                  Electronic Arts TGV video (decoders: eatgv )
     D.V. tgq                  Electronic Arts TGQ video (decoders: eatgq )
     D.V. tqi                  Electronic Arts TQI video (decoders: eatqi )
     D.VI aura                 Auravision AURA
     D.VI aura2                Auravision Aura 2
     D.VI v210x
     D.VI tmv                  8088flex TMV
     DEVI v210                 Uncompressed 4:2:2 10-bit
     DEVI dpx                  DPX image
     D.V. mad                  Electronic Arts Madcow Video (decoders: eamad )
     D.VI frwu                 Forward Uncompressed
     DEV. flashsv2             Flash Screen Video v2
     D.V. cdgraphics           CD Graphics video
     DEVI r210                 Uncompressed RGB 10-bit
     D.V. anm                  Deluxe Paint Animation
     D.V. binkvideo            Bink video
     D.V. iff_ilbm             IFF ILBM
     D.V. iff_byterun1         IFF ByteRun1
     D.V. kgv1                 Kega Game Video
     D.V. yop                  Psygnosis YOP Video
     DEV. vp8                  On2 VP8 (decoders: vp8 libvpx ) (encoders: libvpx )
     D.VI pictor               Pictor/PC Paint
     D.V. ansi                 ASCII/ANSI art
     .EVI a64_multi            Multicolor charset for Commodore 64 (encoders: a64multi )
     .EVI a64_multi5           Multicolor charset for Commodore 64, extended with 5th color (colram)
     (encoders: a64multi5 )
     DEVI r10k                 AJA Kona 10-bit RGB Codec
     D.V. mxpeg                Mobotix MxPEG video
     D.VI lagarith             Lagarith lossless
     DEVI prores               Apple ProRes (iCodec Pro) (decoders: prores prores_lgpl ) (encoders:
    prores prores_anatoliy prores_kostya )
     D.VI jv                   Bitmap Brothers JV video
     D.V. dfa                  Chronomaster DFA
     D.V. wmv3image            Windows Media Video 9 Image
     D.V. vc1image             Windows Media Video 9 Image v2
     DEVI utvideo              Ut Video (decoders: utvideo libutvideo ) (encoders: utvideo libutvide
    o )
     D.V. bmv_video            Discworld II BMV video
     D.VI vble                 VBLE Lossless Codec
     D.VI dxtory               Dxtory
     DEVI v410                 Uncompressed 4:4:4 10-bit
     DEVI xwd                  XWD (X Window Dump) image
     D.V. cdxl                 Commodore CDXL video
     DEVI xbm                  XBM (X BitMap) image
     D.V. zerocodec            ZeroCodec Lossless Video
     D.V. mss1                 MS Screen 1
     D.V. msa1                 MS ATC Screen
     D.V. tscc2                TechSmith Screen Codec 2
     D.V. mts2                 MS Expression Encoder Screen
     D.VI cllc                 Canopus Lossless Codec
     DEVI y41p                 Uncompressed YUV 4:1:1 12-bit
     D.V. escape130            Escape 130
     D.VI exr                  OpenEXR image
     DEVI avrp                 Avid 1:1 10-bit RGB Packer
     ..V. g2m                  GoToMeeting
     DEVI avui                 AVID Meridien
     DEVI ayuv                 Uncompressed packed MS 4:4:4:4
     DEVI v308                 Uncompressed packed 4:4:4
     DEVI v408                 Uncompressed packed QT 4:4:4:4
     DEVI yuv4                 Uncompressed packed 4:2:0
     D.V. sanm                 LucasArts SMUSH video
     D.V. paf_video            Amazing Studio Packed Animation File Video
     D.V. avrn                 Avid AVI Codec
     DEA. pcm_s16le            PCM signed 16-bit little-endian
     DEA. pcm_s16be            PCM signed 16-bit big-endian
     DEA. pcm_u16le            PCM unsigned 16-bit little-endian
     DEA. pcm_u16be            PCM unsigned 16-bit big-endian
     DEA. pcm_s8               PCM signed 8-bit
     DEA. pcm_u8               PCM unsigned 8-bit
     DEA. pcm_mulaw            PCM mu-law
     DEA. pcm_alaw             PCM A-law
     DEA. pcm_s32le            PCM signed 32-bit little-endian
     DEA. pcm_s32be            PCM signed 32-bit big-endian
     DEA. pcm_u32le            PCM unsigned 32-bit little-endian
     DEA. pcm_u32be            PCM unsigned 32-bit big-endian
     DEA. pcm_s24le            PCM signed 24-bit little-endian
     DEA. pcm_s24be            PCM signed 24-bit big-endian
     DEA. pcm_u24le            PCM unsigned 24-bit little-endian
     DEA. pcm_u24be            PCM unsigned 24-bit big-endian
     DEA. pcm_s24daud          PCM D-Cinema audio signed 24-bit
     D.A. pcm_zork             PCM Zork
     D.A. pcm_s16le_planar     PCM 16-bit little-endian planar
     D.A. pcm_dvd              PCM signed 20|24-bit big-endian
     DEA. pcm_f32be            PCM 32-bit floating point big-endian
     DEA. pcm_f32le            PCM 32-bit floating point little-endian
     DEA. pcm_f64be            PCM 64-bit floating point big-endian
     DEA. pcm_f64le            PCM 64-bit floating point little-endian
     D.A. pcm_bluray           PCM signed 16|20|24-bit big-endian for Blu-ray media
     D.A. pcm_lxf              PCM signed 20-bit little-endian planar
     D.A. s302m                SMPTE 302M
     D.A. pcm_s8_planar        PCM signed 8-bit planar
     DEA. adpcm_ima_qt         ADPCM IMA QuickTime
     DEA. adpcm_ima_wav        ADPCM IMA WAV
     D.A. adpcm_ima_dk3        ADPCM IMA Duck DK3
     D.A. adpcm_ima_dk4        ADPCM IMA Duck DK4
     D.A. adpcm_ima_ws         ADPCM IMA Westwood
     D.A. adpcm_ima_smjpeg     ADPCM IMA Loki SDL MJPEG
     DEA. adpcm_ms             ADPCM Microsoft
     D.A. adpcm_4xm            ADPCM 4X Movie
     D.A. adpcm_xa             ADPCM CDROM XA
     DEA. adpcm_adx            SEGA CRI ADX ADPCM
     D.A. adpcm_ea             ADPCM Electronic Arts
     DEA. adpcm_g726           G.726 ADPCM (decoders: g726 ) (encoders: g726 )
     D.A. adpcm_ct             ADPCM Creative Technology
     DEA. adpcm_swf            ADPCM Shockwave Flash
     DEA. adpcm_yamaha         ADPCM Yamaha
     D.A. adpcm_sbpro_4        ADPCM Sound Blaster Pro 4-bit
     D.A. adpcm_sbpro_3        ADPCM Sound Blaster Pro 2.6-bit
     D.A. adpcm_sbpro_2        ADPCM Sound Blaster Pro 2-bit
     D.A. adpcm_thp            ADPCM Nintendo Gamecube THP
     D.A. adpcm_ima_amv        ADPCM IMA AMV
     D.A. adpcm_ea_r1          ADPCM Electronic Arts R1
     D.A. adpcm_ea_r3          ADPCM Electronic Arts R3
     D.A. adpcm_ea_r2          ADPCM Electronic Arts R2
     D.A. adpcm_ima_ea_sead    ADPCM IMA Electronic Arts SEAD
     D.A. adpcm_ima_ea_eacs    ADPCM IMA Electronic Arts EACS
     D.A. adpcm_ea_xas         ADPCM Electronic Arts XAS
     D.A. adpcm_ea_maxis_xa    ADPCM Electronic Arts Maxis CDROM XA
     D.A. adpcm_ima_iss        ADPCM IMA Funcom ISS
     DEA. adpcm_g722           G.722 ADPCM (decoders: g722 ) (encoders: g722 )
     D.A. adpcm_ima_apc        ADPCM IMA CRYO APC
     DEA. amr_nb               AMR-NB (Adaptive Multi-Rate NarrowBand) (decoders: amrnb libopencore_
    amrnb ) (encoders: libopencore_amrnb )
     DEA. amr_wb               AMR-WB (Adaptive Multi-Rate WideBand) (decoders: amrwb libopencore_am
    rwb ) (encoders: libvo_amrwbenc )
     DEA. ra_144               RealAudio 1.0 (14.4K) (decoders: real_144 ) (encoders: real_144 )
     D.A. ra_288               RealAudio 2.0 (28.8K) (decoders: real_288 )
     DEA. roq_dpcm             DPCM id RoQ
     D.A. interplay_dpcm       DPCM Interplay
     D.A. xan_dpcm             DPCM Xan
     D.A. sol_dpcm             DPCM Sol
     DEA. mp2                  MP2 (MPEG audio layer 2) (decoders: mp2 mp2float )
     DEA. mp3                  MP3 (MPEG audio layer 3) (decoders: mp3 mp3float ) (encoders: libmp3l
    ame )
     DEA. aac                  AAC (Advanced Audio Coding) (encoders: aac libvo_aacenc )
     DEA. ac3                  ATSC A/52A (AC-3) (encoders: ac3 ac3_fixed )
     DEA. dts                  DCA (DTS Coherent Acoustics) (decoders: dca ) (encoders: dca )
     DEA. vorbis               Vorbis (decoders: vorbis libvorbis ) (encoders: vorbis libvorbis )
     ..A. dvaudio
     DEA. wmav1                Windows Media Audio 1
     DEA. wmav2                Windows Media Audio 2
     D.A. mace3                MACE (Macintosh Audio Compression/Expansion) 3:1
     D.A. mace6                MACE (Macintosh Audio Compression/Expansion) 6:1
     D.A. vmdaudio             Sierra VMD audio
     DEA. flac                 FLAC (Free Lossless Audio Codec)
     D.A. mp3adu               ADU (Application Data Unit) MP3 (MPEG audio layer 3) (decoders: mp3ad
    u mp3adufloat )
     D.A. mp3on4               MP3onMP4 (decoders: mp3on4 mp3on4float )
     D.A. shorten              Shorten
     DEA. alac                 ALAC (Apple Lossless Audio Codec)
     D.A. westwood_snd1        Westwood Audio (SND1) (decoders: ws_snd1 )
     DEA. gsm                  GSM (decoders: gsm libgsm ) (encoders: libgsm )
     D.A. qdm2                 QDesign Music Codec 2
     D.A. cook                 Cook / Cooker / Gecko (RealAudio G2)
     D.A. truespeech           DSP Group TrueSpeech
     D.A. tta                  TTA (True Audio)
     D.A. smackaudio           Smacker audio (decoders: smackaud )
     D.A. qcelp                QCELP / PureVoice
     D.A. wavpack              WavPack
     D.A. dsicinaudio          Delphine Software International CIN audio
     D.A. imc                  IMC (Intel Music Coder)
     D.A. musepack7            Musepack SV7 (decoders: mpc7 )
     D.A. mlp                  MLP (Meridian Lossless Packing)
     DEA. gsm_ms               GSM Microsoft variant (decoders: gsm_ms libgsm_ms ) (encoders: libgsm
    _ms )
     D.A. atrac3               Atrac 3 (Adaptive TRansform Acoustic Coding 3)
     ..A. voxware              Voxware RT29 Metasound
     D.A. ape                  Monkey's Audio
     DEA. nellymoser           Nellymoser Asao
     D.A. musepack8            Musepack SV8 (decoders: mpc8 )
     DEA. speex                Speex (decoders: libspeex ) (encoders: libspeex )
     D.A. wmavoice             Windows Media Audio Voice
     D.A. wmapro               Windows Media Audio 9 Professional
     D.A. wmalossless          Windows Media Audio Lossless
     ..A. atrac3p              Sony ATRAC3+
     DEA. eac3                 ATSC A/52B (AC-3, E-AC-3)
     D.A. sipr                 RealAudio SIPR / ACELP.NET
     D.A. mp1                  MP1 (MPEG audio layer 1) (decoders: mp1 mp1float )
     D.A. twinvq               VQF TwinVQ
     D.A. truehd               TrueHD
     D.A. mp4als               MPEG-4 Audio Lossless Coding (ALS) (decoders: als )
     D.A. atrac1               Atrac 1 (Adaptive TRansform Acoustic Coding)
     D.A. binkaudio_rdft       Bink Audio (RDFT)
     D.A. binkaudio_dct        Bink Audio (DCT)
     D.A. aac_latm             AAC LATM (Advanced Audio Coding LATM syntax)
     ..A. qdmc                 QDesign Music
     D.A. celt                 Constrained Energy Lapped Transform (CELT) (decoders: libcelt )
     DEA. g723_1               G.723.1
     D.A. g729                 G.729
     D.A. 8svx_exp             8SVX exponential
     D.A. 8svx_fib             8SVX fibonacci
     D.A. bmv_audio            Discworld II BMV audio
     D.A. ralf                 RealAudio Lossless
     D.A. iac                  IAC (Indeo Audio Coder)
     ..A. ilbc                 iLBC (Internet Low Bitrate Codec)
     D.A. vima                 LucasArts VIMA audio
     D.A. AVMEDIA_TYPE_AUDIO   Wave synthesis pseudo-codec (decoders: wavesynth )
     ..A. 8svx_raw             8SVX raw
     DEA. sonic                Sonic
     .EA. sonicls              Sonic lossless
     D.A. paf_audio            Amazing Studio Packed Animation File Audio
     ..A. opus                 Opus
     DES. dvd_subtitle         DVD subtitles (decoders: dvdsub ) (encoders: dvdsub )
     DES. dvb_subtitle         DVB subtitles (decoders: dvbsub ) (encoders: dvbsub )
     ..S. text                 raw UTF-8 text
     DES. xsub                 XSUB
     DES. ssa                  SSA (SubStation Alpha) / ASS (Advanced SSA) subtitle (decoders: ass )
     (encoders: ass )
     DES. mov_text             MOV text
     D.S. hdmv_pgs_subtitle    HDMV Presentation Graphic Stream subtitles (decoders: pgssub )
     ..S. dvb_teletext         DVB teletext
     DES. srt                  SubRip Text
     D.S. microdvd             MicroDVD subtitle
     ..S. eia_608              EIA-608 closed captions
     D.S. jacosub              JACOsub subtitle
     D.S. sami                 SAMI subtitle
     D.S. realtext             RealText subtitle
     D.S. subviewer            SubViewer subtitle
     D.VI bintext              Binary text
     D.VI xbin                 eXtended BINary text
     D.VI idf                  iCEDraw text
    [C:\]
    Nov 2009
    Mexico
    That's the thing - this format isn't listed in the codecs. I just ran one of the wav files through x-WinFF 1.4.2 with the "WAV for CD" preset for the hell of it and it -worked-. It turned the audio files into normal ADPCM WAVs.
    I did a bit of searching and it appears that someone submitted it to libavcodec. And since FFMPEG uses libavcodec, the conversion went through.
    It surprised the heck outta me. I wasn't expecting it to -work-...
    Here's a few sample files in the original, unconverted format:
    https://dl.dropbox.com/u/12145986/Sounds/024.wav
    https://dl.dropbox.com/u/12145986/Sounds/257.wav
    https://dl.dropbox.com/u/12145986/Sounds/326.wav
    And here's the codec I used to get these to play in MPC-HC:
    http://sourceforge.net/projects/ekszbox-abx/files/EkszBox-ABX%20-%20Binary/ (at the top.)
    Thanks for the comments.
  9. DECEASED
    Jun 2009
    Heaven
    Thanks for the codec, I will install it as soon as I find the time to fix that pesky/crappy/b0rked .INF script
    Sadly dropbox.com is unreachable from here , so I will have to wait
    BUT, FWIW,
    Xbox ADPCM audio codec
    Winamp plugin for playing the audio compressed with the Xbox ADPCM codec.
    Supports wave (tag 0x0069), DAT files (like those extracted with the old versions of my XWB/ZWB files unpacker) and XWB/ZWB/WBA/XSD/XSH archives (seen as an unique audio file and with the automatic skipping of WMA and PCM audio).
    ( http://www.winamp.com/plugin/xbox-adpcm/147392 )
    HTH
  10. Originally Posted by El Heggunte View Post
    Don't you have the internets on the moon ?
    Audio
    Format : BYTE_ALIGNED
    Format settings, Endianness : Little
    Codec ID : 69
    Codec ID/Hint : Voxware
    Duration : 462ms
    Bit rate : 397 Kbps
    Channel(s) : 1 channel
    Sampling rate : 22.05 KHz
    Bit depth : 4 bits
    Stream size : 22.4 KiB (100%)
    Nov 2009
    Mexico
    That Winamp plugin doesn't work with these files. It was the first thing I tried.
    I didn't know we could attach files here, thanks for that!
  12. DECEASED
    Jun 2009
    Heaven
    Thanks for the attachments
    So far, I can open them with ffplay.exe. However my hex editor shows that those .WAVs have incomplete headers, therefore it's no surprise Goldwave disliked them.
  13. Member bat999's Avatar
    Feb 2008
    This one.
  14. Originally Posted by Foxhack View Post
    Hmmm... It opens in audacity for me. (As you already figured out ffmpeg can open it, but audacity can be configured to use ffmpeg as well)
    Nov 2009
    Mexico
    I read that ADPCM IMA is very similar to the Xbox codec, but I didn't think it was that close.
    And I didn't know audacity could use ffmpeg either. I'm not very good at this.
    Pardon me, I need to get a dunce hat...
  16. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Converting WAV files that use non-standard codecs
    That makes absolutely NO sense what so ever!!!!
    If it is a wav file, it is a wav file!!!!!
    Nov 2009
    Mexico
    u-Law, ADPCM, GSM... aren't codecs?
  18. Originally Posted by Noahtuck View Post
    No, WAV files can contain audio compressed (or not) with any audio codec.
  19. Member Cornucopia's Avatar
    Including mp3, dts, ac3 (last two are common when dealing with "surround CDs")...
