  1. ..is there a simple tool that can do it for me?
    or do I have to use several to demux, encode, remux..etc..? if so is there issues with timing/oos when doing so..
    I use MKV Audio Converter - wondered if there was anything like that for XVID..?
    thanks
    You could try Avidemux or virtualdub. Under the video choose copy or direct stream copy in virtualdub. And under audio choose a codec. Save as new video.
  3. thanks Baldrick
    Avidemux throws an error saying :
    Cannot setup audio encoder, make sure your stream is compatible with audio encoder (bitrate, channels, format)
    its 6 channel AC3 I need changed to 2 channels AC3 or 2 channel MP3 because the portable TV in bedroom only plays Xvid+mp3 or Xvid+ac3 (2channel)
    thanks for your help
    EDIT: have managed to re-encode the AC3 to 2 channel, will report back if successfull in playback
    Sep 2008
    in avidemux you need to add audio filters to down sample and to convert 6 channel to stereo
  5. Originally Posted by chicken264 View Post
    when converting AC3 (6ch) to MP3 (2ch) yes?
    thanks
    I also need to add black bars too the 720x304 video so that the 16:9 TV keeps the AR - the TV stretches the AR to FULL (fit entire screen, cant be disabled) so I need to add letter-boxing to compensate - what would be the top and bottom width's to make the 21:9 720x304 into 16:9 720x. . . ?
    thanks
    edit : 720 xx 384 - I remembered it lol...cheers
