The MPEG2 I-Frame HD ConverterHow to:
For converting HD files for lag-free usage in Lightworks(Free) on low-end computers
- Drag and drop files to the GUI.
- Set the output directory.
- Hit convert.
- Import in Lightworks by "Create Link"
- And spend your time on the fun stuff - the actual editing.
Downloads:
32-Bit or 64-Bit
(NB. There might be a unicode problem on XP and older OS)
Get the Matrox codecs here.
Motivation:
After spending days trying to figure out to get high quality footage(Canon 60D) into Lightworks without having lagging playback(which all the LW included transcoding formats does and also the much talked about GoPro CineForm codecs) on my ageing computer, I finally tried the Mpeg2 I-Frame HD Matrox codec which Khaver has been mentioning for a long time, and I was really surprised not only did my files convert fast, but they also played without lagging in Lightworks in 1080P resolution. That made me so happy that I spend the night on coding a simple, no fuss(no settings) drag&drop batch converter GUI for ffmbc.exe to convert HD files to the Mpeg2 I-Frame HD format.
Newest version seems to work fine on a test I just ran with XDCam EX input files.
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
Video Converter Support 1080P?
By cccf25 in forum Video ConversionReplies: 8Last Post: 1st Feb 2012, 00:15 -
software options to zoom/crop on a low-end laptop?
By lee09 in forum EditingReplies: 2Last Post: 8th Sep 2011, 03:36 -
low end quadro is 5 times faster than high end gaming card
By deadrats in forum ComputerReplies: 4Last Post: 7th Apr 2011, 16:42 -
Dependability of low end OLD vcr's
By 389poncho in forum Newbie / General discussionsReplies: 13Last Post: 11th Dec 2008, 08:31 -
If I purchase a low end DVD player just to watch movies....
By leftyloopy in forum DVD & Blu-ray PlayersReplies: 8Last Post: 12th Feb 2008, 15:02
