Hi,
I just got a new full HD tv and so decided to download an HD movie.I downloaded the torrent.It says BluRay.x264.x264.mp4.
On the website it said .mp4 so I thought should work on my dvd.My dvd player is Sony DVP 750.It says HD and has also supplied me an HDMI cable.So should it not play an HD file?
It didn't play avis with DIV5 codec so I used AVICC to change it to xvid.
But what do I do in this case?If it does support mp4, then why doesn't it play this file?In vlc codec info it says avc1.So is it a codec problem?
Any programme like AVICC available?
Do I need a bluray player to play HD?If yes, then why does this dvd player say HD and gives me HDMI cable?
Help please..If possible please suggest something that can make this file compatible..I came across AVI CC through this website only.
Thanks.
Nope. Most DVD Players does not support HD video files. It can probably only upscale to HD with the HDMI.
Get a blu-ray player and buy/rent blu-rays instead. -
Thanks!I think I got tricked by their use of generalized terms.He He!
But before I sell this one and get a blu-ray, I would like to try if there is any way to change this mp4 h264 avc format to avi or even the mp4 format that my dvd recognizes..??I would like try before selling it away..
'Coz when I tried directly playing the files, it said format not supported.But then when I converted it to avi format using avidemux (if I am correct), it said Data Error, the same error it gave me when playing avi DIV5 files.I then had run AVICC and changed it to xvid.Which played fine.
Avidemux gives me an avi with h264 which gives me data error on dvd.Tried AVICC but same error.
Help please?
SONY S370 BLU RAY Plyr NOT PLAYING SUBTITILES FOR MP4 format from USB
By Raghavendran in forum SubtitleReplies: 8Last Post: 31st Aug 2013, 13:54 -
DVD works on DVD player but not recognised in laptop
By rline101 in forum DVD RippingReplies: 6Last Post: 11th Oct 2010, 17:09 -
Cyrillic subtitles not shown corectly on DVD player
By uher in forum SubtitleReplies: 1Last Post: 10th Dec 2007, 15:05 -
MP4 files in MOV format - how to play in dvd/divx player
By glen_s in forum Newbie / General discussionsReplies: 1Last Post: 24th Nov 2007, 04:49 -
DVD not recognised in player
By martinbass in forum RestorationReplies: 6Last Post: 6th Oct 2007, 12:32
