Morning all, When using the pan/crop and masking I have an issue.... When doing more detailed masking, I have to scroll into the image to mark the fiddly bits, then scroll out to be able to move the image up or down to complete the rest. When scrolling back in again, how can I carry on from the point where I previously finished on? Is there a video tutorial on detailed masking somewhere? Appreciate some help here. Cheers.
Post a Message.
There are some Vegas experts here but until they chime in, have you looked at this video on feathering your mask?
http://sony-vegas.wonderhowto.com/how-to/mask-sony-vegas-pro-7-178845/ -
When you're zoomed in with the pen tool selected , hold the ctrl key down to toggle the hand tool then move whereever you want (left click mouse button and drag). Releasing ctrl key, brings you the pen tool back (ie. you never have to zoom back out or "lose your place")
Hello Mr Tree Tops,
Nice name my friend. Thanks very much for the tip. I watched it right to the end where he almost tackled my problem, but unfortunately did´nt
I did learn something else from your tip anyway, so thanks for taking the time to answer my question.
Have a super day, much appreciated
P.S. poisondeathray underneath your message solved my problem - cheers mate
Good evening poisondeathray,
I was hoping for a tutorial as I personally find its the best way to learn! But now I´ve learn t otherwise - thanks to you my friend
. Yep, I tried your suggestion out straight away and PRESTO! A problem which I´ve had for nearly 1 year is history! Thanks for taking you time to answer my question, really appreciated.. May I go further and ask you how did you know this? Are you by chance a Sony Vegas pro?
Cheers, and super evening to you...
I´m so pleased now
I use vegas to edit sometimes
For more complex masking operations I use after effects
IMO, the best way to learn is by "doing" . If you get stuck, look for a tutorial (e.g. youtube) or ask in a forum such as this or software specific forum (like sony vegas forum)
Cheers
cant open sony vegas pro 11 'event pan/crop'
By kitsuneee in forum EditingReplies: 7Last Post: 4th Apr 2013, 23:11 -
Pan Crop x2 Sony Vegas
By Compo in forum EditingReplies: 1Last Post: 1st Aug 2012, 13:35 -
Opening Pan/Crop Window (Sony Vegas)
By SaintAin in forum EditingReplies: 2Last Post: 25th Jul 2012, 10:39 -
Sony Vegas Movie Studio 9 Platinum: Event pan/crop keyframing problem
By Dude E. O'Loo in forum EditingReplies: 2Last Post: 22nd Jan 2012, 20:09 -
Cant open the pan/crop window in sony vegas 8.0 pro
By Anonymous5494 in forum EditingReplies: 2Last Post: 28th Jun 2009, 03:25
