I am having some problems trying to convert things with AVCHDCoder.
What I'm trying to do is convert MKV files to make them smaller in sizer, changing the bitrate. And this program was recommended to me here on Videohelp.
So I wonder if anyone is using it.
I'm getting "Error Code 0x0401 - An error occurred while encoding video."
It has already happened with two different files, so now I can't say it was a file problem.
Any hints on what might be happening?
easier to just try some other program. plenty of encoders out there. mediacoder, vidcoder, handbrake, etc....
Did you go through *all* the installation steps?
First of all, have the program install the needed auxiliary programs: splitter, ffdshow, aviSynth, IIRC. AVCHDCoder also has an included utility that can test your configuration. It's touchy about which versions of the above you have. And if you have a codec pack already installed, good luck getting everything to work.
[EDIT] Ripbot can do what you're asking, i.e. re-encode an MKV and output an MKV. AVCHDCoder only outputs AVCHD/Blu-Ray structure.Pull! Bang! Darn! -
Sorry to hear about that.
I haven't played with AVCHDCoder for at least a year, so I was going from memory. I don't have it installed now and don't foresee using it again. But I used it without any ill effects and was able to revert to different versions of the auxiliary software when I uninstalled it.
Anyway, I'd uninstall Avisynth, ffdshow and Haali splitter. With Haali, you should also manually remove the program folder, because it sometimes doesn't uninstall correctly, and a re-install will only be corrupted. Then I'd run CCleaner and reboot before re-installing any of those programs.
I should think that will fix it for you. Maybe re-install your subtitle program as well. If that doesn't do it, you may be looking at an OS re-install.
All I have in the way of codecs are ffdshow and Haali, that's it. Since I started doing it that way, I've had no real problems. Do you have a codec pack installed? That would explain a lot.Last edited by fritzi93; 14th Sep 2012 at 19:53.
Pull! Bang! Darn! -
It's quite likely I will reinstall W7 again, even if I will clean it from those programs as you suggest first.
Now I'm not writing from home, where my desktop is and already processed this file overnight with Vidcoder, to see how it performs when I get back. We'll see if it works and if it's better than Xilisoft, which is my only reference until now but could be improved.
Help me diagnose AVCHDCoder and BD_Rebuilder errors
By ronorkis in forum Authoring (Blu-ray)Replies: 9Last Post: 24th Nov 2013, 12:33 -
MultiAVCHD and AVCHDCoder both just don't work with x264 64bit - Why?
By borst_one in forum Authoring (Blu-ray)Replies: 1Last Post: 19th Jan 2012, 10:12 -
AVCHDCoder + no visible subtitles even there's a stream
By kukkamies in forum SubtitleReplies: 0Last Post: 3rd May 2011, 15:25 -
AVCHDCoder + FFDSHOW = Double subs problem
By kukkamies in forum SubtitleReplies: 4Last Post: 9th Feb 2011, 05:08 -
Multiple blu ray titles-No menu with AVCHDcoder or MultiAVCHD?
By thegeeman in forum Authoring (Blu-ray)Replies: 6Last Post: 22nd Sep 2009, 08:22
