I am just wondering what is the smallest a mp4 video can be and still be HD I am guessing 35mb to 40mb pre 1 min of video. I see a lot of videos at pay sites that are 2.5gb to 4gb these videos are overkill I guess these videos are for anybody using a 55"+ flat screen as there computer monitor there not many people using this big of a screen. I am using a 32" flat screen for my computer monitor and 1.2gb to 2gb videos looks just fine I think pay sites should not have videos bigger than 2.2gb videos if someone knows how to encode mp4s right then most video would be 2.2gb or less
Results 1 to 13 of 13
What you are doing is something like trying to use miles per gallon ratings on cars to figure out the size of an automobile. Or to put it another way, you are asking apple questions in trying to get information about oranges.
Size of video files depends on bit rate.
Whether something is high definition or not depends on resolution (ie. 1280x720) and has nothing to do with bit rate.
Quality is subjective, but for what it's worth we have people here who think that 1.2 - 2 GB is too small for high definition. -
As you have noted, HD is defined as either 1280x720 or 1920x1080.
And jman is absolutely right.
For reference, typical bitrates:
Vimeo recommends 5000kbs
BBC requires minimally 440-800MbsLast edited by smrpix; 14th Sep 2012 at 09:01.
You can reduce luminance resolution - for example 1280x1080 or 960x720 - it is up to You - if Your goal is to reduce bitrate and You are happy on small screen with higher compression in videos this can help a lot.
For typical broadcast quality, common bitrate for H.264 is approx 8 - 12Mbps, for web streaming usually this can be half. -
Yes of course, but are you REALLY going to make me play the game where I have to write a book specifying that "if the file is X size and under Y minutes it is fine" and so forth? The OP joined in 2004 so I would like to avoid playing the games we have to play with new members where we have to explain everything in excruciating detail, but if you are bored and wish to write a lengthy response specifying what should be OK and what shouldn't then please go ahead.
Also, it very strongly depends on the complexity of the content.
THIS VIDEO (below) is 5 seconds of Bars&Tone using h.264 1080p60. It's "HD", and although there are artifacts, those would probably be gone if I doubled the bitrate (to 512kbps!!!). But that's because it's a static screen with solid block colors and no edits.
Scott -
Quick & dirty for this example, I just grabbed a still from the web and some stock tone I had laying around and just dropped it in Vegas & rendered it to RGB 1080p60, then compressed it in QTPro (mainly cuz I know its h264 encoder is lame and I wanted to see if/how it would handle this low a bitrate).
I'm sure a true full Hd "generator" of B&T, with x264 as the encoder, tweaked, would be much better. I was just trying to prove a point.
Scott -
convert mkv to smallest and fastest
By chowa in forum Video ConversionReplies: 3Last Post: 21st Aug 2012, 12:28 -
Smallest FLV output
By curt3006 in forum Video Streaming DownloadingReplies: 5Last Post: 26th May 2011, 12:54 -
best quality smallest size
By Reckitt in forum Video ConversionReplies: 2Last Post: 27th Feb 2011, 09:39 -
smallest file possible in DVD quality
By spiked4life in forum DVD RippingReplies: 6Last Post: 24th Feb 2009, 09:57 -
AVI to MPEG smallest bitrate?
By michcio in forum Video ConversionReplies: 11Last Post: 29th Aug 2008, 20:09
