I am using a xp library computer that has the usb connection disabled. The usb jack is physically connected, because when I connect my mp3 player, I get the usb notification (says drive F) and the mp3 player display shows as being connected to the computer. However, I can't access drive F. I've tried typing F:, using Windows Media and other ways to access the mp3 player but the computer says, access forbidden. I'm wondering if there is a way to bypass the forbidden setting and be able to access my mp3 player.
Frankly, I'm not sure anybody here SHOULD be helping you to do this. The library doesn't want you to use their USB ports for a reason and I don't think you have the right to decide against that.
USB access was turned off by an administrator and it would take administrator access to undo it. But given the problems in China with viruses and such I can't say that wanting to connect ANY device to a library PC via USB is a great idea. But then again you do plumb the depths of idiocy. -
Talk to the librarian. Sometimes it is possible to have a device enabled for the current session - then it deactivates on logoff.
you can read this for an insight:
http://www.novell.com/communities/node/3674/enabledisable-usb-storage-devices-your-network
but i am assuming you're logged as a guest so you'd need admin rights...*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE
Ericsson making human usb connection technology
By yoda313 in forum Off topicReplies: 0Last Post: 11th May 2012, 21:21 -
question about sony bravia usb connection
By ivyer in forum DVB / IPTVReplies: 3Last Post: 1st Nov 2009, 05:53 -
What is the difference in connection of DV and pc between USB and FireWire?
By coody in forum Capturing and VCRReplies: 2Last Post: 11th Dec 2008, 15:17 -
Sky+ usb connection
By shedman in forum Capturing and VCRReplies: 3Last Post: 19th Jul 2008, 12:26 -
USB Port Connection
By BillP2 in forum ComputerReplies: 19Last Post: 27th Sep 2007, 02:49
