I have made a slide show with AVS video editor. It was very simple. All I did was drop the photos in the video time line and they automatically seem to run for the right length of time which is about 3 seconds or so. I then added a mp3 song which I had to edit to make longer. For some reason I couldn't edit the music or photos separately so I just slid the music to the far right of the timeline beyond the slide photo area and edited it there.
I changed the frame rate to 1 frame per second and that came out fine and kept the file size way down. I lowered the bit rate from 1500 to 1,000 but I think I can go much lower for a slide show. So I was wondering if anyone knows what that should be. The slide show with music is just a little over 4 minutes long and the file size is only about 8 megabytes.
Also, I wonder if there is any degradation of the quality of the photos when doing such conversions which I changed to 640 by 320 in the h.264 video format. Do people even use video editing programs to do slide shows?
Is there a better way to do slide shows with music?
Results 1 to 1 of 1
Overall Bit Rate, Bit Rate with Respect to Quality and Filesize
By kingaddi in forum DVD RippingReplies: 113Last Post: 17th Sep 2012, 22:56 -
MediaInfo: Frame Rate vs Original Frame Rate
By adalect in forum Video ConversionReplies: 1Last Post: 19th Aug 2012, 18:44 -
Is there anyway to know the highest bit rate of a video?
By tendra in forum Newbie / General discussionsReplies: 1Last Post: 24th Aug 2010, 23:02 -
How to achieve the maximum bit rate in variable bit rate mode ?
By Sxn in forum Newbie / General discussionsReplies: 42Last Post: 3rd Dec 2009, 13:53 -
Bit Rate And Frame Rate
By bharathi_n_r in forum Video ConversionReplies: 2Last Post: 30th Nov 2007, 06:48
