I'm trying to export video from FFMPEGX and it keeps letterboxing and putting a 'DIV-X' watermark in the corner... How can I fix this?
If your source is 16:9 and you are encoding to DVD, remember to change Autosize in the Video tab from "DVD" (=4:3) to "DVD 16:9". That should prevent big letterbox bars. Additionally, you may turn off "Letterbox" in the Options tab, to have the encoding resized to fit the frame. (Turning this off will resize-to-fit without regard for source aspect ratio, so be sure all other settings match the wanted aspect ratio.)
How do you go from 16:9 720p to 4:3 480p with letterboxing in ripbot?
By yoda313 in forum Video ConversionReplies: 22Last Post: 16th Sep 2012, 09:37 -
Premier CS4 and letterboxing?
By beavereater in forum EditingReplies: 2Last Post: 28th Dec 2009, 22:42 -
Convert 16:9 to 16:10 with letterboxing hardware
By JesterMania in forum Media Center PC / MediaCentersReplies: 4Last Post: 27th Dec 2009, 15:29 -
Letterboxing video for youtube
By cwy in forum Video ConversionReplies: 5Last Post: 2nd May 2008, 09:35 -
Burn in subtitle in a AVI div-x film
By aslan in forum Newbie / General discussionsReplies: 6Last Post: 8th Dec 2007, 11:02
