i want to covert my video MKV audio file VORBIS to AAC what program should i use ?
i dont want to increase the file size.
Maybe popcorn audio converter.
Or avidemux, open mkv, under video choose copy, under audio choose aac. Save as new mkv. -
Whatever you encode with, you will need to use the same bit rate or lower than your Vorbis audio is using or you will end up with a slightly larger file.
May be you want to try Drag Drop Convert GUI
But I have a little suggestion about audio codec, if you want really small file go for HE-AAC this one is pretty small size but it's have chance to lose some quality of sound (some of my mp3 song that has bitrate over 320kbps lose their quality when convert to HE-AAC but 128kbps are very perfect) and I don't think AAC will make a size smaller then Vorbis, so I think you should stick with Vorbis if you try to convert it to HE-AAC but it's lose some quality.
Ps. I still haven't chance to try HE-AAC2 since I can't fine any freeware that accept command line
Hi
neroAacEnc is such an encoder (if you consider this to be 'freeware').
But there are several other aacplus encoders out there on the www.Nero AG licenses you to use this software package for personal non-commercial and/or technology-evaluation purposes.
This License does not provide any rights to reproduce and/or distribute this software package in whole or in any part.
Don't worry about HE-AACv2 though.
It is intended for low bitrates, such as internet radio.
Compare the two tracks attached.
A big difference in quality.
Code:lame test.wav -b 32 test32k.mp3
Code:neroAacEnc -br 32000 -if test.wav -of test32k.m4a
Code:General Complete name : test32k.m4a Format : MPEG-4 Format profile : Base Media / Version 2 Codec ID : mp42 File size : 125 KiB Duration : 30s 232ms Overall bit rate mode : Variable Overall bit rate : 33.8 Kbps Audio ID : 1 Format : AAC Format/Info : Advanced Audio Codec Format profile : HE-AACv2 / HE-AAC / LC Codec ID : 40 Duration : 30s 232ms Bit rate mode : Variable Bit rate : 32.6 Kbps Maximum bit rate : 37.4 Kbps Channel(s) : 2 channels / 1 channel / 1 channel Channel positions : Front: L R / Front: C / Front: C Sampling rate : 44.1 KHz / 44.1 KHz / 22.05 KHz Compression mode : Lossy Stream size : 120 KiB (97%) Writing library : Nero AAC codec 1.5.4.0 Encoding settings : -br 32000
Thanks bat999, but seem like Vorbis still beat HE-ACC v2 in default setting
I encode without setting bitrate so this is bitrate the encode program suggestion.
Code:Format : OGG File size : 3.72 MiB Duration : 4mn 43s Overall bit rate mode : Variable Overall bit rate : 110 Kbps Album : Kyoukai Senjou no Horizon II ED Single -Side SunRise- - Sora no Uta Track name : Sora no Uta Track name/Position : 1/4 Performer : Okui Masami Genre : Anime Recorded date : 2012 Writing application : Lavf54.25.104 Audio ID : 2620846843 (0x9C36F2FB) Format : Vorbis Duration : 4mn 43s Bit rate mode : Variable Bit rate : 112 Kbps Channel(s) : 2 channels Sampling rate : 44.1 KHz Compression mode : Lossy Stream size : 3.78 MiB Writing library : Lavf54.25.104
Code:Format : MPEG-4 Format profile : Base Media / Version 2 Codec ID : mp42 File size : 3.79 MiB Duration : 4mn 43s Overall bit rate mode : Variable Overall bit rate : 112 Kbps Audio Format : AAC Format/Info : Advanced Audio Codec Format profile : HE-AACv2 / HE-AAC / LC Codec ID : 40 Duration : 4mn 43s Bit rate mode : Variable Bit rate : 111 Kbps Maximum bit rate : 126 Kbps Channel(s) : 2 channels / 1 channel / 1 channel Channel positions : Front: L R / Front: C / Front: C Sampling rate : 44.1 KHz / 44.1 KHz / 22.05 KHz Compression mode : Lossy Stream size : 3.77 MiB (99%) Writing library : Nero AAC codec 1.5.4.0 Encoding settings : -q 0.50 -hev2
Hi
HE-AACv2 is used for very low bitrates eg 24Kbps - 32Kbps.
HE-AAC is used for low bitrates eg 48K - 72Kbps.
AAC-LC is used for higher bitrates eg > 72Kbps.
Nero will decide.
Code:neroAacEnc -help
Note that the above switches (-lc, -he, -hev2) should not be used; optimal AAC profile is automatically determined from quality/bitrate settings when no override is specified. -
Oh, I don't know about that.
Thanks again, bat99
Ps. 24kbps seem lose some quality so I use 32kbps as minimum.
megui convert video how to keep orginal aac audio
By jamespoo in forum DVB / IPTVReplies: 0Last Post: 24th Jun 2011, 22:11 -
Convert MP4 AAC Audio possible?
By kazz0817 in forum AudioReplies: 4Last Post: 18th Apr 2011, 02:42 -
I need an idiot's guide to converting PCM to AAC or Vorbis!!!
By Nagashi in forum AudioReplies: 6Last Post: 4th Jul 2010, 17:07 -
Convert h.264 MP4 w/AAC 5.1 audio to AVI file w/AC3 5.1 audio for Xbox 360
By ycrazyy in forum Newbie / General discussionsReplies: 6Last Post: 14th Jan 2010, 15:25 -
Convert AAC 6ch to AAC 2ch w/ Dolby Pro Logic II Surround info
By SiegeX in forum AudioReplies: 5Last Post: 28th Dec 2009, 16:58
