How can I fix this???
Did a google and found this-
http://community.skype.com/t5/Windows/SOLUTION-Skype-muting-PC-Audio-from-Notification...tc/td-p/539943I think,therefore i am a hamster. -
If you are using Windows 7, also check your windows sound settings.
Go to control panel then the "sound" item. A window with tabs marked, playback, recording, sounds, communication should open up. Select the communication tab and check the "do nothing button". I have not test this yet but sounds to me like that may have an effect on Skype.
Skype Audio
By Jappyanime in forum AudioReplies: 1Last Post: 14th Jul 2012, 04:59 -
Get HD Video on Skype, etc with camcorder?
By dainova in forum Video Streaming DownloadingReplies: 1Last Post: 22nd Nov 2010, 20:16 -
Sony Vegas 7.0 mutes audio upon normalisation command?
By 2prfm.com in forum EditingReplies: 0Last Post: 30th Jul 2010, 04:10 -
half way into video it mutes
By jerbear10 in forum MacReplies: 3Last Post: 27th Dec 2009, 22:19 -
Quickly adding short mutes or volume dips? Editing curses.
By ejp in forum AudioReplies: 8Last Post: 19th Oct 2008, 22:55
