  1. hello
    i found vob file and it has colour problem.so how can i adjust hue of that file without loosing quality ?
    please help
    thanks
  2. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Use VOB2MPEG to convert (losslessly) the VOB to MPEG2.
    Then use a video editor to adjust the colour.
    (e.g. Avidemux)
    You will have to use filters then reencode when you save the file.
  3. thanks i will try
  4. avidemux isn't good. output video isn't in good quality.
    any other suggestion please ?
