Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
Results 1 to 16 of 16
  1. Hello i am having problems with mpc the original aspect ratio for the .mkv file is 4:3 but i used mkvmerge to make it 16:9, mpc still displays the video as 4:3. i have already set "keep aspect ratio" but it does nothing and disabled "read Ar from stream" but no change. here is a sample file
    http://www.mediafire.com/?lmemddb19nrekhu
    and here is the information from mediainfo
    General
    Unique ID : 235007942482742696009297645721995054622 (0xB0CCE223DB65CC79A347B1D623F20E1E)
    Complete name : C:\Users\Aliyu\Videos\Kannagi.avi-muxed (1).mkv
    Format : Matroska
    Format version : Version 2
    File size : 2.71 MiB
    Duration : 1mn 54s
    Overall bit rate : 198 Kbps
    Encoded date : UTC 2012-09-09 20:29:50
    Writing application : mkvmerge v4.4.0 ('Die Wiederkehr') built on Oct 31 2010 21:52:48
    Writing library : libebml v1.0.0 + libmatroska v1.0.0
    Video
    Format : AVC
    Format profile : High 10@L3.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 10 frames
    Muxing mode : Header stripping
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 1mn 54s
    Nominal bit rate : 173 Kbps
    Width : 640 pixels
    Height : 480 pixels
    Display aspect ratio : 16:9
    Original display aspect ratio : 4:3
    Frame rate : 10.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 10 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.056
    Writing library : x264 core 125 r2200 999b753
    Encoding settings : cabac=1 / ref=10 / deblock=1:1:1 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=0.40:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=100 / keyint_min=10 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=173 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=81 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=2:0.60
    Audio
    Format : AAC
    Format profile : HE-AAC / LC
    Codec ID : A_AAC
    Duration : 1mn 54s
    Channel(s) : 2 channels
    Sampling rate : 44.1 KHz / 22.05 KHz
    Compression mode : Lossy
    Delay relative to video : 33ms
  2. cant anyone pls help me
  3. It plays as 16:9 for me in MPC-HC by default. But it's fairly obvious to me that it's supposed to be 4:3. What a mess that video is. 10fps?
    Maybe update your player.
  4. Originally Posted by manono View Post
    i am using MPC-HC.1.6.3.5818. this video is just an example of the problem i am having with a lot of videos i convert
  5. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Huh ?!?!?
    All Mkvmerge does is mux elementary streams, it does not convert or change anything......
    It is a "muxing" program, not any kind of converter.
  6. i know that. what i mean is that after i have used megui some times i forget to change the aspect ratio so i use mkvmerge to re-mux it to 16:9 but it still plays at 4:3
  7. Use a different MKV reader/splitter.
  8. Hey theunk,
    I am with manono ... I just downloaded your Sample and used "Media Player Classic Home Cinema 1.6.2.4902 (X86)" and it played as 16:9 by default. BTW, I tried in VLC Media Player 2.0.3 (X32) and played A-OK too.
    Q: Are you using x32 or x64 of your version MPC-HC?
    Or try using an Older version ... may be MPC glitch!
    G!
  9. The AR information isn't being passed through the various filters required to play a video. Use a different MKV reader/splitter. Also check the codecs. Be sure you don't have "Override Aspect Ratio" set to Default, not forced to another AR.
    Of course, the bigger problem is your video is 4:3 DAR, not 16:9.
  10. @gonwk
    i am using the 32 bit ver i have used new an old mpc the give me the same problems
    @jagabo
    i did use a different MKV reader/splitter still got the same outcome, but i found out that if i should tick h264/avc (ffmpeg) it solves the issue but then i cannot watch movies that are 10bit encoded.
  11. DECEASED
    Jun 2009
    Heaven
    Perhaps there is a *bug* in your video card's drivers ???
    Anyway, play that file on other computer(s), or try different video renderers, and see if this makes some difference...
  12. Originally Posted by theunk View Post
    MPCHC's internal h264/avc (ffmpeg) decoder played your sample for me. The DXVA version doesn't.
  13. Yes as mentioned above MPC-HC with internal filters will display the AR correctly but pass it to to external filters i.e. LAV and the aspect ratio gets lost or ignored.
    The way I get around these things is change the source AR directly rather than worry about display AR. This tool will change SAR for AVC/h264 for you:
    http://forum.doom9.org/showthread.php?t=152419
  14. @chug a bug
    thanks alot that works for me. i really appreciate it
  15. Generally the way it seems to work, at least as best as I can tell, is if the "View/Video Frame/Keep Aspect Ratio" option is checked (from the top MPC-HC menu) it'll use the container display aspect ratio. With that option unchecked, it'll use the original aspect ratio. I don't know if it applies for every possible combination of splitters/renderers etc, but....
    Check to see if "Keep Aspect Ratio" is checked, as your sample also plays using a 16:9 aspect ratio for me.
    Why are you needing to change the aspect ratio after encoding with MeGUI? In most cases MeGUI should get it right so the encode should display using the correct aspect ratio without you needing to change anything.
  16. Originally Posted by hello_hello View Post
    That's the problem. Not all combinations of filters pass the AR information properly.
