Hi, i'm playing a specific MKV file, and for some reason LAV does not want to de-interlace it, even if I force de-interlacing to always occur.
Any ideas? I'm using WMP with Media foundation disabled.
wild guess: video is not interlaced, but progressive and someone messed up creating it by encoding an interlaced source as progressive,...
-> post detailed MediaInfo analysis (if you use a CLI version of Mediainfo: detailed = --FullHelp; if you use the GUI version of MediaInfo, set Debug to 10) -
Most likely it was resized and the two fields are no longer separate. Post a sample.
Well this is very odd. If I mux the video stream alone (no audio or subtitles), it de-interlaces it like it should do. yet If I then mux it (using the video-only MKV i'd just created) with audio and subtitles, it goes back to not de-interlacing it. :S
OK i've narrowed it down. If I mux the audio in, it plays fine and deinterlaces properly, yet the moment I mux the subtitles (PGS) onto it, it stops de-interlacing properly, it's wierd as i've had PGS subtitles in all my other M2TS to MKV movies and they've gone through OK. Still, i can live without subtitles for this one though.
Blu-Ray to MKV with forced subtitles - Size of file not issue
By rajsharma714 in forum Blu-ray RippingReplies: 3Last Post: 16th Nov 2012, 22:25 -
Blu-Ray 1080i source > MKV, confused about deinterlacing
By Phat J in forum Video ConversionReplies: 0Last Post: 25th Aug 2011, 00:42 -
MKV TO BD-R with forced subtitles
By wthldh in forum Video ConversionReplies: 6Last Post: 21st May 2010, 11:19 -
MKV to AVI - But retaining forced subtitles...
By peejay1977 in forum Video ConversionReplies: 1Last Post: 18th May 2010, 05:00 -
New capture card recommendations with some specfic features?
By justin81 in forum Newbie / General discussionsReplies: 2Last Post: 6th Jul 2009, 13:00
