Hi,
A couple of years ago I purchased "AVerTV Super 007" (AVerMedia M135-A PCI Analog). Recently I installed a new OS - Windows 7 64Bit, and since then I can't run the "AverTV" application. The version of the drivers package that I installed is 3.6.64.15, and everything looks fine in the "Device Manager". When I try to run the "AVerTV" application I see nothing on the screen. for a couple of seconds the computer "thinks" and it seems something is going to happen, but nothing really happens at the end. I don't get an error message.
Did you encounter this issue in the past and know how to solve it?
In any case, can you recommend a similar software (a program that I could use in order to watch VHS cassettes on my computer) that would work on Windows 7 64Bit? It's better if it would be a freeware.
Thanks in advance,
Kuros
Try install latest aver pack (30/12/2010). Probably have new driver inside.
Link: http://www.avermedia.com/Support/DownloadCount.aspx?FDFId=4657
For new software try AMAREC TV (freeware). Awesome tv application viewer.
Claudio
DV Capturing problem with Windows 7 64Bit
By freak2010 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 21st Feb 2018, 10:34 -
Best ripping tool for Windows 7 64bit
By Hal05154 in forum Blu-ray RippingReplies: 8Last Post: 13th Nov 2011, 21:12 -
move to 64bit windows
By beavereater in forum ComputerReplies: 31Last Post: 28th Oct 2011, 00:39 -
Windows 7 64bit Video processing software?
By Browncoat in forum Newbie / General discussionsReplies: 3Last Post: 26th Apr 2010, 07:37 -
Windows Vista - 32bit or 64bit?
By HatchetMan in forum ComputerReplies: 29Last Post: 12th Jan 2008, 01:24
