Results 1 to 16 of 16
  1. Member vhelp's Avatar
    Mar 2001
    New York
    while browsing the stores, i saw a tablet and randomly seletected youtube videos. then a tipicle youtube webpage listing of clips came up and i randomly seleted Jessie J. I did not know anything about her, ever..until i saw the mvideo, 'price tag' i said to myself, later on, i'll search youtube (with my new youtube scrapping app) and find her. so far i have not been able to see any of her mvideo clips since they are all marked private or MTA or VEVO private. but the clip i just saw came up in my player and i thought it was very high quality for the resolution.
    i was surfing the youtube channels and came across this (IMO) HQ 360p clip, ok except for when theres movement, oh well.
  2. Member vhelp's Avatar
    Mar 2001
    New York
    test 2, w/out attachment.
    edit: ok that worked. now i get it.. post the image here, where no one see them anyway. and later, post it in a forum discussion, vuala! EGGcellent.
  3. Member vhelp's Avatar
    Mar 2001
    New York
    smplayer youtube quality mode settings:
  4. Member vhelp's Avatar
    Mar 2001
    New York
    youtube.blocked.opera
  5. Member vhelp's Avatar
    Mar 2001
    New York
    ..and, youtube.unblocked.IE8
  6. Member vhelp's Avatar
    Mar 2001
    New York
    this is SMPlayer's playlist window
  7. Member vhelp's Avatar
    Mar 2001
    New York
    ..and here is a slightly better SMPlayer playlist window -- you can use the [NAME] field as comments, so i discovered.
    Caption for post#5...
    "I'm a big girl now. I have hair in my pits!"
  9. Member vhelp's Avatar
    Mar 2001
    New York
    example of popup message problem in opera even though scripts (F12) are turned off.
  10. Member vhelp's Avatar
    Mar 2001
    New York
    vh ads are showing up ok on my end..
  11. Member vhelp's Avatar
    Mar 2001
    New York
    youtube playlist html coded, demo 1
    i was struggeling how to html code it..finally, i figure out how.
  12. Member vhelp's Avatar
    Mar 2001
    New York
    results from recuver (file undeleter) test scenario.
  13. Member vhelp's Avatar
    Mar 2001
    New York
    dos prompt here example.
  14. Member vhelp's Avatar
    Mar 2001
    New York
    corruption in prev post of images. now posting new, here.
    open dialogbox, how do i reconfigure default view to Details ? (topic already posted elsewhere)
  15. DECEASED
    Jun 2009
    Heaven
    o-kay .........
  16. Member vhelp's Avatar
    Mar 2001
    New York
    advc-100 not recignized under windows xp home.
    only the sony trv-22 dvcam is recignized.
    device manager screen shot.
    dv connection status.
    device mgr list
    screen capture topic, locking onto a frame rate, a vdub prep demo, bla bla bla
    pinnacle studio moviebox plus, model 710-usb
    vlc issue with smooth/fluid video play when 59.94 frame rate used
    pic from IMdb, king kong escapes
    pic of that old makeavis.exe tool
    ex of icons on status line, looking for tweak utility to re-order them
    internet speed
    bmp2avi utility, how do calculate frame duration in milliseconds ?
    bmp2avi utility, how do calculate frame duration in milliseconds ? [solved]
    GIJoeTheRiseOfCobraTrailer, d/l link takes me to link to d/l binary exe file instead of the mkv movie d/l
    ilo.dvdr04 dvd recorder and annoying dv stop/play/pause/rw/fw on screen image
    Image Attached Images
