  1. Hello there all, im new here and id like a hand with this file, mediainfo incoming:
    General
    Unique ID : 230070924963782325561106387902133241044 (0xAD160C621C87216DBBD6DCBAB45104D4)
    Complete name : I:\Berserk_Golden_Age_Arc_I_Egg_of_the_Supreme_Rul er_(2012)_[1080p,BluRay,flac,x264]_-_Taka-THORA\Berserk_Golden_Age_Arc_I_Egg_of_the_Supreme_ Ruler_(2012)_[1080p,BluRay,flac,x264]_-_Taka-THORA.mkv
    Format : Matroska
    Format version : Version 2
    File size : 3.81 GiB
    Duration : 1h 16mn
    Overall bit rate : 7 103 Kbps
    Movie name : Berserk Golden Age Arc I: Egg of the Supreme Ruler (2012)
    Encoded date : UTC 2012-06-10 09:30:16
    Writing application : mkvmerge v5.3.0 ('I could have danced') built on Feb 9 2012 10:38:07
    Writing library : libebml v1.2.3 + libmatroska v1.3.0
    Attachment : Yes / Yes / Yes / Yes / Yes / Yes / Yes
    Video
    Format : AVC
    Format profile : High 10@L4.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 3 frames
    Muxing mode : Header stripping
    Codec ID : V_MPEG4/ISO/AVC
    Width : 1 920 pixels
    Height : 816 pixels
    Display aspect ratio : 2.35:1
    Frame rate mode : Variable
    Original frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 10 bits
    Scan type : Progressive
    Writing library : x264 core
    Language : Japanese
    Default : Yes
    Forced : No
    Audio
    Format : FLAC
    Format/Info : Free Lossless Audio Codec
    Codec ID : A_FLAC
    Duration : 1h 16mn
    Bit rate mode : Variable
    Channel(s) : 6 channels
    Sampling rate : 48.0 KHz
    Bit depth : 24 bits
    Writing library : libFLAC 1.2.1 (UTC 2007-09-17)
    Language : Japanese
    Default : Yes
    Forced : No
    Text
    Format : ASS
    Codec ID : S_TEXT/ASS
    Codec ID/Info : Advanced Sub Station Alpha
    Compression mode : Lossless
    Language : English
    Default : Yes
    Forced : No
    So id like to watch this on my 360 but gotsent v23 qnd 24beta8 have failed me... been doing that alot lately... ive also tired xenonmkv but it seems the the FLAC audio throwing it off. so as them were my go to programs i think ill have to remux this by hand, id like to keep the quailty as high as i can, so ask yourselves the question how would you make this work?
    thank you.
  2. Been pulling my hair out... i got this file to mp4 and playable on my 360, using MKVExtractGUI i got the raw Audio FLAC, out and converted it to acc with this little package i found http://minitheatre.org/forum/13-guides/109886-converting-6-channels-flac-to-2-channels-nero-aac.html
    Anyway i put it all back togther with mkvmergeGUI and this time xenonmkv handeled it just fine, now many new problem.... I got to hardcore the subs and i just cant figure it out, Id really like some help guys...
    Edit: Ok ok just tried Xvid4psp And i get error
    Caching: DirectShowSource can't decode video (zero-size image was returned)!
    at XviD4PSP.Caching.worker_DoWork(Object sender, DoWorkEventArgs e) in C:\XviD4PSP\windows\Caching.xaml.cs:line 84
    import("C:\Program Files\XviD4PSP 5\dlls\AviSynth\functions\AudioFunctions.avs")
    import("C:\Program Files\XviD4PSP 5\dlls\AviSynth\functions\VideoFunctions.avs")
    DirectShowSource("C:\Users\Ken\Desktop\Berserk_Gol den_Age_Arc_I_Egg_of_the_Supreme_Ruler_(2012)_[1080p,BluRay,flac,x264]_-_Taka-THORA\Berserk_Golden_A
    ge_Arc_I_Egg_of_the_Supreme_Ruler_(2012)_[1080p,BluRay,flac,x264]_-_Taka-THORA.mkv", fps=23.976, convertfps=true)
    when i try loading the video...
