i usually use Chrome , but for online videos i have to use Firefox , way superior ..
i get all kinds of playback issues with chrome : shuts down , sync , etc ...
But with firefox it's a really smooth run (even if chrome is still open with multiple tabs)
I know FF has a great ability with add-ons and plugins ..
is there any easy tweak possible for chrome for better playback ??
Results 1 to 10 of 10
firefox has is own flash player ??
should i try uninstall and reinstall the active x or plugin version ..
maybe firefox uses one and chrome the other .. i don't realy know -
I've read, somewhere, that Chrome bundles the Flash plugin inside the browser package (as chicken264 indicated - though it's actually the same components you're normally installing, and not anything specially created for Chrome), so it won't depend upon any versions of Flash installed separately. That does mean you're dependent upon Google to update it for you, though. Have you made sure Chrome is up-to-date?
I've also heard of people replacing the Flash components within Chrome to a more recent version, but as I don't use Chrome, I never really looked into it, and don't know if there's any risk involved in doing it.
If cameras add ten pounds, why would people want to eat them? -
i've uninstalled adobe flash (plugin and activex) with CCleaner and reinstalled it from adobe's website
My Google Chrome browser is now up to date
Now the adobe flash activex is missing (uninstalled) from my add/remove list from CCleaner ,
(i don't remember where i got it from . is it software or browser related , i don't know)
Firefox still plays smoothly and chrome still has difficulty
(can't really tell if it's better or worst, maybe a bit better)
the missing activex doesn't seam to affect playback for better or for worst
is the activex needed ?? -
do you get the playback issues with Chromium? Install it + flash player and report back
http://www.chromium.org/getting-involved/download-chromiumI love it when a plan comes together! -
check this page from Google support helps
http://support.google.com/chrome/bin/answer.py?hl=en&answer=108086
I also do not use chrome for my regular use. I use it in office to debug my cgi -
ActiveX is ONLY for Internet Explorer. If you don't us IE, then don't even bother installing it. If you do, us IE (not Firefox or Chrome) to get it from the Adobe website.
I Can't Play Flash Video in Firefox
By Tom Saurus in forum Video Streaming DownloadingReplies: 7Last Post: 18th Jun 2012, 17:25 -
Adobe Flash Video Encoder
By Cunhambebe in forum Newbie / General discussionsReplies: 2Last Post: 27th Nov 2009, 00:33 -
Adobe Flash Player - 64 bit
By orfajackson in forum Newbie / General discussionsReplies: 4Last Post: 30th Jun 2009, 14:39 -
.swf (flash) videos not displaying in Firefox
By KameronK in forum Video Streaming DownloadingReplies: 3Last Post: 4th Mar 2009, 11:42 -
Adobe Flash now supports H.264
By lordsmurf in forum Latest Video NewsReplies: 0Last Post: 4th Dec 2007, 11:08
