I inherited a Canon XL2 that uses firewire to transfer. However, my HP Touchsmart 300 doesn't have a firewire port and it can't be added. Does anybody have any recomendations to get the files onto the pc? I've considered a portable hard drive w/ firewire. will that work? Anything cheaper or easier, or both?
Nope.I've considered a portable hard drive w/ firewire.
But when googling for 'Canon XL2 USB' and looking at the results, it sound like buying a cable like:
source: http://www.cellularfactory.com/camcorder/CANON/4/35617/306480/For the Canon XL2 Camcorder: Digital Camera Data Cable USB 2.0 Olympus CB-USB4, Nikon UC-E4, Kodak U-5A, Canon IFC-300PCU,IFC-400PCU ,Sony VMC-14UMB2,Pentax I-USB6,SAMSUNG AH39-00498AG)for you to use to connect your digital device to your laptop, PC computer to transfer photos and other files that support by the digital device.
With the charging function, you can also charge your digital device via a USB port.
The USB2.0 certified cable supports data transfer rates up to 480 Mbps and are fully backwards compatible with all USB 1.0 and 1.1 devices.
Easy to use, plug and play. Or refer to your digital device provide to get the available software.
is probably the easiest solution. -
4$ for a cable might be worth a try,.... (if you got an electronic store not too far from your place you could ask them if the let you try the cable before you buy it,..)
other than that you would probably need something like a 'Moviebox' from Pinnacle, afaik these should allow to connect DV Cams to it and copy the content to a pc,.. -
I don´t think it will be worth it. JonFC is correct, simple USB to firewire adapter/cables just won´t work (not for transfering DV camcorder video anyway)4$ for a cable might be worth a try,.... (if you got an electronic store not too far from your place you could ask them if the let you try the cable before you buy it,..)
I don´t know if there are many other choices but this one does work, I have used it succesfully for such a task:
http://www.bhphotovideo.com/c/product/681351-REG/Pinnacle_8230_10068_41_Studio_Moviebo...ollection.html -
The moviebox is a great idea. That is an all around solution for me. Thanks
Just wanted to let you know that the Pinnacle MovieBox works great. It was easy to install, computer detects the camera, and imports film quickly. Thanks for help.
How to Cut & Merge mini 10 part mini series?
By skorpinok in forum EditingReplies: 5Last Post: 8th Oct 2011, 09:41 -
Capture progressive mini-dv tape on interlaced mini-dv cam ?
By alip in forum Capturing and VCRReplies: 4Last Post: 8th Feb 2011, 17:27 -
Matrox MX02 Mini or Matrox MX02 Mini Max
By Cingular in forum Capturing and VCRReplies: 0Last Post: 14th Oct 2009, 20:27 -
Mini DV Help
By sdf91 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 7th Jan 2009, 22:08 -
Hardware choices: standalone mini-DV deck, or cheap mini-dv camera?
By SgtRauksauff in forum Newbie / General discussionsReplies: 3Last Post: 14th Oct 2008, 02:18
