When I create an multi chaptered AVCHD using aultiAVCHD, or a single file for that matter, all appears to go well and the structure appears intact except the Audio is weak and it is made up mostly of "white noise" which is 75% of the audio. The log file shows transcoding some failure under Haali, Avisynth and ffdshow, which I've uninstalled and reinstalled (64bit if avail) a couple times and authored the folder again using multiAVCHD making sure the match the bitrate and checked one of the stream files and the same white noise exists.
The original mp4 files are PCM and play fine. The multiAVCHD Authored stream files are AC3 and playable but are they 75% missing and replaced with noise.
I know I need to give more info but I'm just not sure what?
Results 1 to 1 of 1
No Audio on PS3 with MultiAVCHD
By Exaile in forum AudioReplies: 5Last Post: 7th Apr 2012, 17:14 -
multiAVCHD audio bitrate?
By morghe-sokhari in forum Newbie / General discussionsReplies: 0Last Post: 16th Feb 2012, 10:11 -
Audio gain in MultiAVCHD
By Zetti in forum Video ConversionReplies: 0Last Post: 16th Sep 2010, 13:46 -
Sound turned to white noise when using TMPGEnc Xpress & DVD Author
By Hal05154 in forum Authoring (DVD)Replies: 4Last Post: 15th Jan 2009, 23:03 -
Coping VHSC tapes to DVD+r, lost content due to white noise
By PanMan in forum Capturing and VCRReplies: 2Last Post: 25th Sep 2008, 21:54
