Hi, i'm in a wedding videography business & want to burn a Blu ray with having all option of setting up menu, putting pictures in the background, playing music as a background music on the menu screen, just like it could be done in Idvd. i bought Leawo & burnt my first blu ray it all went well but when i played it on my ps3 it did not let me rewind or forward one movie but it did allow me second one in the same blu ray. i then burnt another blu ray to test then it worked fine at first but when i came out of all the chapters & then went to play it again then it did not let me rewind or froward at all. long story short i think this software have some issues like that so i'm looking for someone who can help me in fixing this or if there is any other better software, even if software is a paid i need something which is professional & which saves time too.
Results 1 to 15 of 15
I'm moving you to our mac section.
Can you rewind and forward on your computer when you play the blu-ray with a software blu-ray player? -
tsMuxer Gui does it (it creates a BluRay structure, ready to burn)
but it needs an m2ts or ts file (previously encoded by a third software)
PS: Eyetv captures its files as (mpeg-)ts. Soi its file are -most of time- compliant with tsMuxer
byeFor DVD, iPad, HD, connected TV, … iMovie & FCPX? MovieConverter-Studio 3 (01/24/2015) - Handle your camcorder's videos? even in 60p or 60i? do a slow-motion? MovieCam. -
tsmuxer is not what you want. It can't create menus. Herve did not understand your requirements.
As far as your PS3 issue goes, I know nothing about Leawo. The PS3 is somewhat temperamental and it may have problems with what Leawo creates. Did you create an AVCHD disc or a BluRay disc? Did you use single layer or dual layer BD discs to burn to? Who made your BluRay disc and what type is it (BD-R, BD-RE, BD-R LTH, etc.)?
No offense but I am really getting the feeling that for a guy in the "wedding videography business" that you've got really weak technical video skills. I think you are going to need a lot of hand holding to pull this off. There aren't a lot of options under Mac but take a look at Toast as maybe it can do what you want. -
Hi,
I created a Blu ray disc not AVCHD. I used single layer blu ray disc. my blu discs are sony made & it BD-R. I have tried toast titanium already & found that its menu are not very fancy & we prefer to use a selected image to be coming up as a background, im again not sure wether it does it or not. hope this information helps you!!! -
[QUOTE=rollingcanvas;2186066] Toast does ugly menus, but does menus
tsMuxer does no menu at all
…and I don't know any other soft that handle bluRay (except these two)
PS: I didn't try with new version, but -with far earlier versions- you could hack menus: find where is located Toast's background images and replace them by your own…
That's not great (you will still obtain an "ugly toast-like menu") but it's to only option to customize menu
And I don't know any other solution on Mac
(…or use a PC)
If you want Blu-ray creation WITH menus & other fancy features, and you HAVE to do it on a Mac - use Adobe Encore. Nowhere near as capable as PC BD apps, but that's your choice...
Scott -
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 05:15 -
How to burn blu ray files on dvd without encoding?
By aruwin in forum Blu-ray RippingReplies: 3Last Post: 9th Oct 2010, 12:14 -
Burn 1-5 dvd's on one blu-ray?
By Kotten-74 in forum Authoring (Blu-ray)Replies: 1Last Post: 18th May 2008, 15:45 -
Burn standard DVD project to Blu Ray disc?
By whoisquilty in forum Authoring (DVD)Replies: 12Last Post: 24th Feb 2008, 15:21 -
Burn DVD and Blu Ray discs using Premeire Elements
By bornplaydie in forum Authoring (DVD)Replies: 0Last Post: 21st Feb 2008, 17:38
